turkishbosher666 Occasional Visitor
Posted: Fri Nov 13, 2020 5:56 pm Post subject: Transferring saved favourites to a in built car satnav |
Hello
Need help at preset I have a Garmin. 2599 with loads of saved favourites, how do I transfer these to my in built car satnav,Suzuki vitara infotainment system 2016,
Any help apprenticed.
Thanks |
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4457 Location: West Sussex
Posted: Fri Nov 13, 2020 6:32 pm Post subject: |
If your built in satnav will accept .gpx files then your favourites can be found in current.gpx on your nuvi. If your built in satnav wont accept .gpx files then let us know what it will accept? _________________ Where there's a will ... there's a way. |
BigJohnD Frequent Visitor
![](http://bigjohnd.org.uk/SatNav/Avatar-C4WRC.jpg)
Joined: Aug 26, 2007 Posts: 397 Location: Glannau Mersi, Lloegr
Posted: Sat Nov 14, 2020 1:54 pm Post subject: |
The manual suggests POIs can be added in standard .CSV format. |
Posted: Sat Nov 14, 2020 2:19 pm Post subject: |
POIs and favourites are different though, at least in Garmin speak. If it'll take .csv files then you could load your favourites into BaseCamp and export them as .csv files. _________________ Where there's a will ... there's a way. |
Posted: Tue Nov 17, 2020 3:46 pm Post subject: |
Thanks for all your replies converted the gpx files to CSV but still no joy |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15155 Location: Bradford, West Yorkshire
Posted: Wed Nov 18, 2020 9:28 am Post subject: |
BigJohnD wrote: | The manual suggests POIs can be added in standard .CSV format. |
Is this a physical manual or an online one we can look at? |
Posted: Wed Nov 18, 2020 1:25 pm Post subject: |
MaFt wrote: | Is this a physical manual or an online one we can look at? |
See here, Page 52: http://www.suzuki-slda.com/Lists/User%20Manuals/User%20manual%20SLDA%20Europe_EN.pdf
8.12.1 Data format
The file containing your own points of interest must comply with the WGS84 standard.
The required file format is “.csv”.
Each line of the file may describe one point of interest containing the following pieces of information:
ffLongitude
ffLatitude
ffName
ffAddress (optional)
ffTelephone number (optional)
A line of the file may look like this:
77.61,12.92,Park,Bangalore City,00917829 |
Posted: Wed Nov 18, 2020 3:20 pm Post subject: |
Downloaded a few poi's
A tried everything suggested no joy, driving me nuts now what am I doing wrong? example of one of the poi's that I've done.
"myPOI-Warnings_csv"2.362751.38143 Bath Monmouth At local
[/img] |
Kremmen Pocket GPS Verifier
![](modules/Forums/images/avatars/4810985884fb0a2b6dedb3.gif)
Posted: Wed Nov 18, 2020 4:41 pm Post subject: |
turkishbosher666 wrote: | Downloaded a few poi's
[/img] |
That doesn't look right..
It should be something like :
-2.71,51.81,Monmouth
But that depends on the Lon/Lat required. Some require a NSEW notation as well.
From what I can find it needs to follow the WGS84 standard _________________ Satnav:
Car Average MPG :
Posted: Wed Nov 18, 2020 7:12 pm Post subject: |
"myPOI-Warnings_csv"2.362751.38143 Bath Monmouth At local |
Assuming "myPOI-Warnings_csv" is the filename then it needs to be .csv at the end and not _csv. If there is no '.' shown then you will need to 'unhide' file extensions and make sure it is a .csv file.
'CSV' stands for Comma Separated Values - i.e. in the main file each field is marked by a comma. The contents of the file above does not have any commas. It should be:
Code: | 2.3627,51.38143,Bath Monmouth At local |
which would have the name as 'Bath Monmouth At local'
or
Code: | 2.3627,51.38143,Bath Monmouth,At local |
which would have the name as 'Bath Monmouth' and the address/details as 'At local'
Hope this helps |
Posted: Fri Nov 20, 2020 11:08 am Post subject: |
Thanks for everyone's replies tried everything suggested but still not working, infotainment system doesn't recognise any files on usb drive,so going to use my Garmin for safety camera warnings not Ideal,as just wanted to use the 1 system for everything,but not happening ☹️☹️☹️ |
Posted: Fri Nov 20, 2020 12:27 pm Post subject: |
Even if you got the upload to work, many systems are not capable of producing the advance warning that cameras require.
If you can bluetooth your phone to the head unit consider using CamerAlert or SpeedTrap Alert, both of which produce PGPSW directional alerts. _________________ Satnav:
Car Average MPG :
Posted: Mon Nov 23, 2020 11:26 am Post subject: |
turkishbosher666 wrote: | Thanks for everyone's replies tried everything suggested but still not working, infotainment system doesn't recognise any files on usb drive,so going to use my Garmin for safety camera warnings not Ideal,as just wanted to use the 1 system for everything,but not happening ☹️☹️☹️ |
If you email me the file I can take a look and see if there's anything obvious: MaFt AT pocketgpsworld DOT com |
