Posted: Sat May 16, 2020 8:53 am Post subject:
@dales
I must hold my hand up in apology. I tried quite hard to break it, but, unlike your good self, failed miserably as I didn't know how to do it wrong.
Why would anyone even think that unzipping and processing the same file more than once was a bad idea and break the A DIFFERENT prog? Much to my everlasting shame I sure didn't, so I can only congratulate you on you [s]lateral[/s] weird thinking.
Having said all that, I was not actually talking abut the extended length of time that you took to replicate the problem once it had been found, but the length of time that the prog has been around before the problem was found.
Serious: I wonder what caused the first "13" when you installed the new version? Strange. I had no such problem.
Posted: Sat May 16, 2020 9:26 am Post subject:
Puzzled me as well.
A fresh unzip would have removed all existing .CSV files then replaced them with good ones.
The surefire check now is that when you perform the download and unzip, or just the unzip, the first thing that should happen is 4 white boxes with no data.
If you see 4 green boxes, with data, and an enabled Process button then Houston you have a problem. You should only see the 4 green boxes after a 'process' not before. _________________ Satnav:
Car Average MPG :
Joined: May 10, 2004 Posts: 160 Location: Garstang, Lancashire
Posted: Sat May 16, 2020 9:35 am Post subject:
I am as puzzled as you three are. I have been trying to remember in what order I pressed buttons when the problem appeared to me last weekend, but I can't remember.
I promise to be more careful in the future !!! _________________ Jonial
Posted: Sat May 16, 2020 11:29 am Post subject:
I would try to break it.
What you did should not be possible now. It was a definite bug under the right order. _________________ Satnav:
Car Average MPG :
Page 4 of 4
