willmow Regular Visitor
Posted: Wed Jan 15, 2020 12:08 pm Post subject: Zumo 660: where do POIs go? |
I've updated my Mac OS to Catalina, which means my Garmin POI Loader had to be updated, which means I now have to browse for the destination of the PGPSW POIs. Does anyone know the name of the file I am looking for so I can insert it in POI Loader? _________________ Where there's a will - there's me! |
Kremmen Pocket GPS Verifier
Posted: Wed Jan 15, 2020 12:52 pm Post subject: |
4th in the list 'Garmin POILoader' _________________ Satnav:
Car Average MPG :
Posted: Wed Jan 15, 2020 3:23 pm Post subject: |
Kremmen wrote: | 4th in the list 'Garmin POILoader' |
Not with you, Kremmen?
Having run tests, it looks like the PGPSW POIs land up in a folder in the Zumo called Poi, in a file called poi.gpi
Does this sound right?
Then the question is, how do I know if the POIs are being accessed properly by the satnav? _________________ Where there's a will - there's me! |
Posted: Wed Jan 15, 2020 4:07 pm Post subject: |
Oh, I thought your question is which to download.
POILoader will place the resultant. GPI file in the correct place for your device, which is usually the POI folder.
The POI name will be the name that POILoader shows in the name panel and the name is unimportant.
If you already have numerous mysterious POI's in that folder then run the POILoader option to remove all existing ones first then load the new one. _________________ Satnav:
Car Average MPG :
sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4457 Location: West Sussex
Posted: Wed Jan 15, 2020 4:37 pm Post subject: |
willmow wrote: |
Then the question is, how do I know if the POIs are being accessed properly by the satnav? |
Do a where to, categories, custom POIs and you'll see what is loaded. _________________ Where there's a will ... there's a way. |
Posted: Sun Jan 19, 2020 7:11 pm Post subject: |
Test post - please ignore _________________ Where there's a will - there's me! |
Posted: Sun Jan 19, 2020 7:15 pm Post subject: |
Tx to Kremmen and Sussamb.
On the Zumo 660, it appears that POI Loader puts the PGPSW data in a file called pgpsw-speed-cams-ZbV4-(18-011).gpi in an existing folder called Poi.
On the Zumo, I found what looks like relevant data by going: Where To -- Extras -- Custom POIs.
I used POI Loader to remove existing POIs from the Zumo before uploading the new batch as Kremmen suggested.
Question: does the weekly batch of data we get reload every POI in the PGPSW database, or does it only include changes to what's already there - in other words, by deleting my old POIs, have I destroyed my own database? _________________ Where there's a will - there's me! |
dales Frequent Visitor
Joined: May 04, 2008 Posts: 752 Location: Knaresborough, North Yorkshire.
Posted: Sun Jan 19, 2020 9:22 pm Post subject: |
Yes, the weekly download of speed cameras is the full database of all cameras. _________________ nuvi 2599LMT-D, oregon 700, basecamp, memory-map. |
Posted: Mon Jan 20, 2020 12:06 am Post subject: |
Then all is well that ends well. Thanks to all. _________________ Where there's a will - there's me! |
Posted: Mon Jan 20, 2020 6:08 am Post subject: |
That filename is going to cause issues.
By default POIloader creates its filename based on the Windows folder name. My Windows folder name is "PGPSW" and I always extract into that, so my Garmin file is always "PGPSW.GPI" This means that every week POILoader prompts me to overwrite the existing device GPI file.
With that filename, which is linked to a single download, will not get overwritten and you will end up with multiple camera files unless you remember to delete the existing file.
What I think you've done is allow Windows to use its suggested folder name when you extracted the zip.
Be careful _________________ Satnav:
Car Average MPG :
Posted: Mon Jan 20, 2020 8:25 am Post subject: |
Tx Kremmen, I'll see what happens next time and adjust as necessary. As it happens, I have a Mac.
If I use POI Loader to delete previous POIs, does this also delete any other POIs I may have that are not generated by PGPSW? _________________ Where there's a will - there's me! |
Posted: Mon Jan 20, 2020 8:46 am Post subject: |
If you delete existing first then you'll be OK.
Exactly what the delete option removes I don't know. I manually removed all the Cyclops ones before running mine. _________________ Satnav:
Car Average MPG :
Posted: Mon Jan 20, 2020 8:54 am Post subject: |
I think I'll do the same thing. BTW, how does Cyclops compare with PGPSW? _________________ Where there's a will - there's me! |
Posted: Mon Jan 20, 2020 9:37 am Post subject: |
Cyclops is considered by us not as up to date as here, plus, all you get from Cyclops is a small blue dot and just a beep.
Both of which don't grab your attention like the PGPSW alerts with proper individual speed icons and a spoken alert.
All Cyclops has in its favour is that it's directional. _________________ Satnav:
Car Average MPG :
