sussamb Pocket GPS Verifier
Joined: Mar 18, 2011 Posts: 4457 Location: West Sussex
Posted: Sat Aug 03, 2019 10:11 pm Post subject: |
Then you must have a .gpi file somewhere. Are you on a Mac? If so empty the trash. Either way ensure you're doing a full search of your device, and card if one is installed, for any stray .gpi files, there will be at least one somewhere. _________________ Where there's a will ... there's a way. |
dales Frequent Visitor
Joined: May 04, 2008 Posts: 752 Location: Knaresborough, North Yorkshire.
Posted: Sat Aug 03, 2019 10:31 pm Post subject: |
Yes, there must be a gpi file somewhere.
As said, check on your SD card if your device has one installed.
(I put my own camera gpi files on my SD card eg so I can whip it out if I'm in France).
Dales. _________________ nuvi 2599LMT-D, oregon 700, basecamp, memory-map. |
Kremmen Pocket GPS Verifier
Posted: Sun Aug 04, 2019 6:12 am Post subject: |
You've probably got this covered, but, when I need to search my Garmins I have the 3 main settings:
View file extentions
View hidden files
View system files
Plus, get the device out of MTP mode for just a single session
All set to view everything because Garmin can be restrictive.
Once all the above is set you should be able to detect the offending GPI file.
The 'view system files' is particularly important because on a Garmin that also hides folders and I'm guessing your GPI could be in a hidden folder. _________________ Satnav:
Car Average MPG :
rabbitseggs Occasional Visitor
Posted: Wed Aug 21, 2019 9:53 pm Post subject: Garmin Drive Smart 61 LMT-D |
Thanks everyone
Deleted all POIs and garmin cameras using the PC. Reloaded POIs including PocketGPSWorld Speed cameras and the rouge files have now all gone and everything is working as it should. Thanks again. |
