Kremmen Pocket GPS Verifier
Posted: Sun May 19, 2019 10:26 am Post subject: CA via car headunit |
Having just changed my phone I wanted to make sure the new phone was going to issue the CA alerts over the cars speaker system via the headunit.
Having Bluetooth paired the phone I started CA, went into settings. Changed it to 'Bluetooth Headset' and then changed the output from 'Male Voice' to 'Female Voice'.
When you do that CA fires off a verbal sample through the car system so you can adjust the volume to suit.
= no need to go out and drive past a camera to test and adjust.
Proper Job ! (from the garage) _________________ Satnav:
Car Average MPG :
M8TJT The Other Tired Old Man
Posted: Sun May 19, 2019 2:20 pm Post subject: |
Good tip K. |
DennisN Tired Old Man
Posted: Sun May 19, 2019 6:20 pm Post subject: |
Same result if you change the advance warning. _________________ Dennis
Two of them are obesiting!! |
Posted: Sun May 19, 2019 6:23 pm Post subject: |
The real question is whether you get the same problems as I do - crashes when you try to input a voice note, disables audio after you get a phone call and a warning together, blackscreen when warning at night (there's a simple solution to this last one - turn off night view and blind yourself). _________________ Dennis
Posted: Mon May 20, 2019 4:54 am Post subject: |
I've never encountered those because they've never cropped up.
No one ever phones me on the mobile (except those single ring 0843/0845 scammers)
Never go out at night, but, I run with no maps so it's only displaying cameras in range on a black background anyway
Never use the phone for verification _________________ Satnav:
Car Average MPG :
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15152 Location: Bradford, West Yorkshire
Posted: Mon May 20, 2019 8:55 am Post subject: |
DennisN wrote: | The real question is whether you get the same problems as I do - crashes when you try to input a voice note, disables audio after you get a phone call and a warning together, blackscreen when warning at night (there's a simple solution to this last one - turn off night view and blind yourself). |
Those are iOS issues. Kremmen, I believe, is sensible and uses Android. |
Posted: Mon May 20, 2019 1:29 pm Post subject: |
Sure does _________________ Satnav:
Car Average MPG :
Posted: Mon May 20, 2019 1:38 pm Post subject: |
MaFt wrote: | Kremmen, I believe, is sensible and uses Android. |
So long as he hasn't got a Huawei phone?
Is the fact that I use iOS the reason why CamerAlert is not being updated? Do Android phones get CamerAlert updates? _________________ Dennis
Posted: Mon May 20, 2019 3:08 pm Post subject: |
I've got a Sammy phone, just upgraded from a HTC. It's quite thin considering it's got Pie inside.
I find it hard to understand why our beloved Gov are in favour of allowing this HooHar mob a hand in our communications, especially if some are sensitive.
Factoid: Huwaei have an office complex on Green Park in Reading. According to a friend who worked in the block next door all employees in there are Chinese. Not a single IC1 seen entering or leaving the building in the 7 years he worked next door - suspicious they only employ their own in the UK ! _________________ Satnav:
Car Average MPG :
