Posted: Mon Apr 16, 2018 4:15 am Post subject:
If you've used POILoader to populate the SD card and the end result is being able to see the xxx.GPI file on the card then it could be a matter of going through the units menu to see if you have to put a tick or check next to the POI category to activate it.
I javen't noticed any previous comment about selecting active/non active POi's _________________ Satnav:
Car Average MPG :
Joined: Jun 04, 2005 Posts: 128 Location: Radlett, Hertfordshire
Posted: Mon Apr 16, 2018 11:47 am Post subject:
Hi Kremmen.
I reckon I have pushed every button there is, explored every option.
The SD card shows the .gpi file is on it, but the Garmin just cannot see it. (Reminds me of a Spec Savers TV ad') Perhaps I should say, pointing finger: It's over here !!
But I don't think that will work either.
99% sure it's a breakdown in communication. Will need a dealer sort out.
Awaiting a reply from dealer, my PCP is ending soon so might be inclined to help as they will then want to sell me another car.
Posted: Mon Apr 16, 2018 6:47 pm Post subject:
M - I did a Google on "Kenwood Garmin GVN60".
One of the hits is 'owners manual rg-sound' it's a PDF and page 42 shows that POi's work exactly like our units with the 'Where to ~ Categories ~ Custom POi's' being the actual command structure. _________________ Satnav:
Car Average MPG :
Posted: Mon Apr 16, 2018 8:00 pm Post subject:
[quote="M8TJT"]
Can you define the above 'doesn't work' please.
On your device, try "Where To" ~ "Custom POIs". Do the bowling clubs show there? (Menu options might be a little different.
1. What are you expecting it "to do"?
2.What is it "doing"?
When I put the SD card in the socket nothing happens on the GVN60.
The manual on page 42:
...After downloading your POI database, use the Garmin POI Loader to install the POIs onto an SD card. Use the SD card to load the POIs.
NOTE: The unit may restart when you insert an SD card.
Finding Custom POIs:
You can view a list of custom POI's loaded in your navigation system.
Select Where to? / Categories / Custom POIs
Somewhere I have read I need to be in a MAP screen before loading POI's
On my device there is no 'Custom' POIs option shown to be able to select it. I assume that is because I have not actually managed to load any? The only BOWLS are Garmins own 10 pin bowling alleys.
What do I expect it to do? Recognize the SD card and load the POIs.
What is it doing? Refusing to recognize the SD card.
Posted: Mon Apr 16, 2018 11:16 pm Post subject:
Thanks for the low down on that trapper.
What you must bear in mind about my apparently inane questions is that I don't have your satnav, so don't know what to expect when you plug the SD card into it.
But I do know what to expect on my Honda setup (Garmin satnav) and my DS 61.
My main ignorance of your system is that is it meant to upload the POIs from the SD card onto the main device, or are the POIs accessed direct from the SD card. If the latter, it is obvious that the SD card has to be left in.
You seem to have done everything right as far as getting the gpi file in the right place on the SD card, so I give in.
Posted: Tue Apr 17, 2018 8:28 am Post subject:
Gentlemen.
We, but mostly you, have gone far further than could be expected, for which I thank you both.
When I get the new cable and have made an appointment with the dealer I will take a range of SD cards along with me so we can try them all in case there are any oddities in file format or structure. FAT FAT32, Bowls Clubs, poi, etc.
When we get to the bottom of the problem I will post it here.
M. Sometimes I do question my sanity, I thought that when I retired I would have some spare time, relax and take it easier, how wrong I was.....
Posted: Tue Apr 17, 2018 10:29 am Post subject:
Doesn't it say in the manual that all 'your' POI's go into "poi.gpi" _________________ Satnav:
Car Average MPG :
Posted: Tue Apr 17, 2018 6:14 pm Post subject:
So when you say 'not seen'
That's means that when you press Where to - Categories - Custom POi's, there is nothing there ? _________________ Satnav:
Car Average MPG :
Posted: Tue Apr 17, 2018 7:47 pm Post subject:
dales wrote:
trapper wrote:
I then made a 3rd card, formatted to FAT
File structure
Garmin\POI\poi.gpi
You might just try FAT32 and Garmin\POI\poi.gpi, to complete the testing options.
Dales.
Thanks, I did that one later, same result. Sorry to say.
Just been to the car, selected Where to? There are categories listed; restaurants, art, recreation, lodgings, Petrol Stations etc etc. But there is no heading or mention of 'Custom POIs' listed.
I am sure the problem lies either in the installation or the connection of the extension cable or the cable itself.
May I ask, to those that are using a Garmin Satnav and even better the same GVN60, what format do you use, FAT or FAT32 or ??.
Also, can you have two or more 'Custom POI's' For example Bowls Clubs and National Trust locations, and be able to select either as a heading in the Satnav? I ask in the assumption that at some point I will be able to install any POI's that is.
Joined: May 04, 2008 Posts: 752 Location: Knaresborough, North Yorkshire.
Posted: Tue Apr 17, 2018 11:03 pm Post subject:
The SD card in my own Garmin satnav (freestanding) is formatted FAT32. (I have just checked !)
Yes you can have lots of categories of Custom PoI on your SD card. Certainly I have !
In the PC folder that PoiLoader looks at, I have lots of matching pairs of .csv files and .bmp files, for each of my desired categories of PoI (eg Accommodation, Attraction, Bookshop etc). [So there are Accommodation.csv and Accommodation.bmp and so on]. I got these PoI's from this PGSW site !
Now, on the satnav, when I go to Where to - Categories - Custom POIs, I can see a nice list comprising All Categories, or Accommodation, Attraction, Bookshop etc.... And if I select one of those categories, I can see a nice list of those entries, in order of the nearest, so that I can select it as a destination.
[The PC filing system can be slightly less simple than this, if you have seriously many categories of PoI, but we can ignore this for now].
