fredbloggs123 Occasional Visitor
Posted: Thu Dec 27, 2012 4:47 pm Post subject: On ios 6 'also run' is missing coppilot |
I have just got an iphone 4s and in the CamerAlert settings the 'On startup also run' is missing 'Copilot'. It's only showing 'Nothing' or 'Maps'? How do I get it to show Copilot so that I can select that it starts copilot as my android version does. |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15146 Location: Bradford, West Yorkshire
Posted: Fri Dec 28, 2012 12:47 am Post subject: |
As far as I'm aware Co Pilot does not have the required custom URL scheme to be able to do this.
The easiest way to see if it does have one is to see if it has an option of emailing or sharing your location with other users. If it does then the link it sends to other iPhone's will show the URL scheme we need to use - it would be something like copilot://?lat=52.123&lon=2.123 or similar. The part we/you need is the copilot://
MaFt |
Posted: Fri Dec 28, 2012 12:48 am Post subject: |
OK, just checked - CoPilot 9 DOES have the sharing - you need to enter copilotv9:// to the also run text box. We will get this added in the next update, but for now you can enter it manually.
MaFt |
Posted: Fri Dec 28, 2012 3:51 am Post subject: Sorted, MaFt you are a star! |
Temp fix has done the trick. Amazed I'm the only one who has noticed!
Now if you can just design a way to exit CamerAlert instead of having to do the double home push thing.
Thanks again. |
Posted: Fri Dec 28, 2012 4:08 pm Post subject: Re: Sorted, MaFt you are a star! |
fredbloggs123 wrote: | Now if you can just design a way to exit CamerAlert instead of having to do the double home push thing. |
We did used to have an 'exit' button. But Apple rejected the app for it as it doesn't meet their guidelines. Feel free to fight it out with Apple yourself...
MaFt |
Posted: Fri Dec 28, 2012 4:09 pm Post subject: |
The other option is to turn off tracking (cross hairs at bottom left) and tap the home key. With the tracking turned off the app will be closed by the OS when the memory is needed.
MaFt |
