Pocket GPS World :: View topic - iOS 6 !
iOS 6 !
Goto page 1, 2, 3  Next
adobbing
PostPosted: Wed Sep 12, 2012 11:52 am    Post subject: iOS 6 ! Reply with quote
Just made copies of my mapsettings.cfg file and all my added content (.OV2, .PNG, .OGG etc.).
I seem to remember that when they last updated iOS it wiped all of these!
So if iOS 6 arrives tonight, it may be worth making a backup now before you lose them !
adobbing
PostPosted: Wed Sep 19, 2012 11:58 am    Post subject: Reply with quote
Apparently iOS 6 will arive some time later today!
Time to make another backup of all the relevant files from my iPhone 4S!
adobbing
PostPosted: Wed Sep 19, 2012 9:05 pm    Post subject: Reply with quote
Updated to iOS 6!
Just tested TomTom App and it appears to have kept all POI files and mapsettings.cfg file
Recent destinations etc all O.K. !
ViperZx
PostPosted: Thu Sep 20, 2012 2:45 pm    Post subject: Reply with quote
No, iOS 6 blocked access!!!
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=85133&start=480
You canīt copy (Diskaid) pois to the Folder anymore!
After OTA-Update from 5.1.1 the pois exist but with the next TomTom-Update the pois are deleted. And you canīt (thanks iOS6 Sad ) copy new.
PostPosted: Thu Sep 20, 2012 3:07 pm    Post subject: Reply with quote
It probably just needs Disk Aid to update to work with iOS 6 devices?
adobbing
PostPosted: Thu Sep 20, 2012 3:32 pm    Post subject: Reply with quote
My TomTom app is working fine, my POI's and warnings unaffected.
If what you mean is that a TomTom app update is due, I would firstly make a backup of the current app, usually found in your iTunes/Mobile Applications folder on your computer and store safely in another location.
If you update the app and then want to revert to this version, you just need to delete the Updated app and replace with this backed up copy of the app.
Then delete the application from your iPhone/iPad.
From iTunes on your computer type in the name of the old app ticking the check box and synchronising with your device.
Hey presto you will be back to the original version!
I will avoid updating the TomTom app until I know that disk aid is working again.
st1967
PostPosted: Thu Sep 20, 2012 6:02 pm    Post subject: Reply with quote
How annoying is this going to be.
My colleague is getting her iPhone 5 tomorrow and I'm having her old iPhone 4 for a steal so that is good on the 1 hand but the problem I can see looming fast on the horizon is she has updated it to IOS6 already so she can backup and migrate to the new phone tomorrow !!
Even with a factory reset it will still be on IOS6, so I'll have to do the same on my 3GS to be able to backup and restore.
Do you see where I am going? A Restore to the iPhone 4 will not bring the Custom POIs with it? Well it didn't when I did a backup and restore when I was having problems with my 3GS. I had to diskaid the custom POIs and sounds back on afterwards.
Lets hope somebody cracks it in the next week Sad
Samsung S22 Android, Google Maps & Camera Alert
st1967
PostPosted: Thu Sep 20, 2012 6:12 pm    Post subject: Reply with quote
Looks like there is a new version of Diskaid out (5.4) I quote from the changelog
Current Version: DiskAid 5.4
Release date: September 13, 2012
New in this Version:
Fully iOS 6 and iPhone 5 compatible
Here's hoping that does the trick? I may update my 3GS (I will need to anyway to migrate to new phone) and give it a try.
wazzzzupmate
PostPosted: Thu Sep 20, 2012 8:47 pm    Post subject: Reply with quote
I am running Diskaid 5.4 and IOS 6 and can no longer copy over any custom POI files to the TomTom Iphone app.
Tomtom Go 400
Tomtom 1.15.1 for Iphone
ViperZx
PostPosted: Thu Sep 20, 2012 9:09 pm    Post subject: Reply with quote
I used v5.4, no way.
The support says: Restart Computer and Device. Rolling Eyes
st1967
PostPosted: Thu Sep 20, 2012 11:36 pm    Post subject: Reply with quote
I did the update and get the same.
It does seem to be a permissions thing because try and delete a file and it says "permission denied" you can however copy to the documents folder?
I'm sure some of the clever bods will work out what to do.
PostPosted: Fri Sep 21, 2012 12:27 pm    Post subject: Reply with quote
Likely due to the new sandboxing and increased security.
adobbing
PostPosted: Fri Sep 21, 2012 2:15 pm    Post subject: Reply with quote
I have some possibly good news for you!
I have been trying all morning (with the help of apple technical) to clone over my 4S contents to my new iPhone 5.
It initially refused to restore from the backup of my 4S, throwing up an error message
By a process of elimination I got it to work and here is how...
1 Get your old device connected to iTunes and rename it to the standard "iPhone" anything else I tried caused problems later.
2 remove (by unchecking the tick boxes) all the music, books, etc, these should be retained on your computer within iTunes, this will be make the backup far smaller.
3 do a further backup and check in the edit/ preferences/ devices that you have a backup called "iPhone"
4 then connect you new iPhone 5 and after running through the basic instructions on screen, get to restore from backup.
5 pick the "iPhone" backup and let it synchronise.
Et Voila!
It copied over all my settings, text messages etc.
Most importantly it copied TomTom with all it's POI's, custom warnings etc.
So much less hassle from having to start from scratch!!!
Once it has synchronised the first time you can then re-tick all the boxes and copy over music, contacts, books etc
st1967
PostPosted: Fri Sep 21, 2012 4:31 pm    Post subject: Reply with quote
Great, thanks. Although I'm not as lucky as you my friend I'm moving from a 3GS to a 2nd hand iPhone 4, but hopefully the principal is the same.
I feel so cheap Embarassed
While it will be great to at least get the current POIs over we're still stuck with these and cannot update the speed cameras etc. Plus when the next upgrade for TomTom appears it is likely to wipe them all permanently.
I fear Jail-braking may be the only solution if indeed even that allows access?
adobbing
PostPosted: Fri Sep 21, 2012 4:39 pm    Post subject: Reply with quote
The crucial thing for making sure that you can restore from the backup, seems to be to ensure that both devices have the same name.
Page 1 of 3
Đ Terms & Privacy
