Pocket GPS World :: View topic - Dividing a track
Dividing a track
stormin7039
PostPosted: Fri Sep 14, 2012 9:37 am    Post subject: Dividing a track Reply with quote
As a result of forgetting to reset and convert a trail I have ended up with a large combined track that needs separating into two.
Is there any way I can do this using SatSync, Route Converter etc?
Thanks.
rothers
PostPosted: Fri Sep 14, 2012 11:08 am    Post subject: Reply with quote
I edit my tracks in memory Map
AliOnHols
PostPosted: Fri Sep 14, 2012 12:15 pm    Post subject: Reply with quote
If you can find the .gpx version of the big track you can open it on your computer using a text editor such as NotePad. Find the end and start points using the time stamp and then it is a simple cut and paste job to create two new tracks.
You may need to keep a few of the Header and Footer lines of the BIG track and make them common to both of the smaller, new tracks.
Garmin Nuvi 2599
SatMap Active 10 & 20.
stormin7039
PostPosted: Fri Sep 14, 2012 10:47 pm    Post subject: Dividing a track Reply with quote
Thanks for the suggestions.
The method of opening the gpx file with notepad and copying and pasting works very well, and can be done without downloading any new software. I hadn’t realised that gpx files could be opened using notepad.
As you pointed out, it is necessary to copy in the headers and footers from the original big file into each of the small files to enable them to be recognised as gpx files.
Many thanks for the information.
