Pocket GPS World :: View topic - GPS BlueTooth Recievers
rainbowbridge1
PostPosted: Sun Jul 03, 2011 4:49 pm    Post subject: GPS BlueTooth Recievers Reply with quote
Do GPS bluetooth recievers increase your signal strengh are they worth buying?
PostPosted: Sun Jul 03, 2011 5:16 pm    Post subject: Reply with quote
It really depends upon what device you aim to pair it with and the type of car you are using it in, for example if the car has an athermic windscreen a BT GPS in the rear window has a better chance than a phone mounted in the front.
Most modern phones won't see much of an improvement if used in normal cars that are supplied without coated windscreens - Mike
Duddy
PostPosted: Sun Jul 03, 2011 11:31 pm    Post subject: Re: GPS BlueTooth Recievers Reply with quote
As you know I've a HTC Desire and I've tried a BT receiver but there's no improvement over screen mounting the Desire.
The main problem was I couldn't use my BT repeater for directions/ calls etc at the same time.
HUAWEI P30 Pro (new edition) with Speedtrap Alert & alcatel1 for SatNav
CoPilot 10 with CamerAlert
RoadHawk in-car video
Reading glasses getting thicker as is my waist
Retired but want to go back to work for a rest.
Watchmaker
PostPosted: Mon Jul 04, 2011 8:05 pm    Post subject: Reply with quote
I am using a BT gps aerial with my HTC Wildfire and the improvement is dramatic.
The first fix is much quicker and exiting from a tunnel it re-aquires in less than 10 seconds.
20 quid on ebay and its solar too. no power cable needed on short journeys.
regards, Frank.
nayanuk
PostPosted: Fri Nov 09, 2012 9:07 pm    Post subject: Bluetooth GPS receiver Reply with quote
May be it is too late to write it down. Anybody has problem getting enough GPS satellite reception to get accurate positioning, can buy Qstarz 818x or XT Bluetooth gps. It will give you 8-9 satellite reception even in Scottish canyon.http://www.amazon.co.uk/Qstarz-BT-Q818x-Bluetooth-Sat-Receiver/dp/B002LJS8SE/ref=sr_1_4?s=electronics&ie=UTF8&qid=1352491568&sr=1-4
