Posted: Mon Jul 26, 2010 2:04 pm Post subject: Help with Thunderbird, please?
On my main desktop PC I run Mozilla Thunderbird. I have several other gadgets email capable, but not comprehensively. I can on them all use webmail, but it's not too easy.
My new laptop is Win 7 and has wi-fi, so I can use that for webmail out and about, but for four different webmail addresses handling some 18 different email addresses it's a real pain.
What I'd like to do is have Thunderbird on it, running the same way as my desktop.
I have found that T'bird has a profile folder which (I think) contains all my settings and mail folders and messages. If that would transfer over, maybe I'd get what I want.
Information I've found is the profile folder lives somewhere (I have found it) and is called xxxxxxxx.default, where the Xs are an eight character random name generated by T'bird.
My thinking is.....
A) Copy that default folder (1.8GB)
B) Download and install T'bird to laptop.
C) Find the default folder on the laptop and note the random name.
D) Rename the copy of my PC default folder to the same as the folder on the laptop and simply copy and replace.
Hey presto, when I fire up T'bird on the laptop it'll have all my folders, filters, messages and settings from the PC, so I can do mail from the laptop in future instead of the PC.
How does that sound? Smartypants or Numpty? _________________ Dennis
Joined: Aug 31, 2005 Posts: 15154 Location: Bradford, West Yorkshire
Posted: Mon Jul 26, 2010 2:48 pm Post subject:
copy the profile folder and paste into your new laptop.
feel free to rename it something sensible, it's not important. put it in an obvious location, eg in the root of C:\ or in My Documents - so if you need to move it again then it's far easier to find!
now, install thunderbird on the new laptop BUT don't run it yet.
click on the start icon (circlular windows logo, bottom left of task bar) and type the following:
Code:
thunderbird.exe -p
this will launch the profile manager. click the option for 'New' and then 'choose existing folder' (or words to that effect). point it to your (renamed) profile folder, and click ok/next etc. then, back on the profile manager screen, set that as the default one and make sure the box for 'show on startup' is unticked, otherwise you will get shown the option of which profile to use each time. you can also, if you want, delete the default profile that was created when you installed thunderbird.
Posted: Mon Jul 26, 2010 2:53 pm Post subject:
PS - one thing to watch out for, depending if you are using POP3 or IMAP.
if using POP3 then any email you download on your PC will NOT be available on the laptop. and vice versa - any email downloaded on the laptop WILL NOT be on the PC.
if you are using POP3 and you download the emails (i.e. when you go on webmail any emails that have been downloaded to PC are not available in webmail) then you should do the following (assuming you want the emails downloaded to the laptop as the main device:
1) disconnect PC and Laptop from the internet.
2) in thunderbird on the PC go to the account settings and for each account, under server (i think) change the setting to keep the mail on the server (i.e. you can 'download' the emails on the PC but they will still be available for the laptop to download)
3) set the laptop to download the emails, i.e. NOT keep them on the server.
if you plan on using both the PC and the Laptop for sending/receiving emails then i would recommend using an IMAP server as this would mean sent items and drafts etc would be shared between computers - however, as all the mail is stored on the server you would need to check how much storage space you get and, if your internet is down, you can't view the emails...
Posted: Mon Jul 26, 2010 3:18 pm Post subject:
Thanks MaFt. I have three POP3 servers and one IMAP. The POP3 servers are all already set to keep emails on server for 30 days. _________________ Dennis
Posted: Mon Jul 26, 2010 3:24 pm Post subject:
in which case just carry out my first reply and all existing settings, plugins/addons and emails, filters etc etc will be transferred to the new laptop.
you can also do this to move your mail to a mac too. so much simpler than trying to import into mac mail etc...!
had a job following that not being familiar with thunderbird or mozzila or perhaps just too long in the tooth, anyway I use Mailwasher pro to sort out the wheat from the chaff and then Mail downlaods all my email address,s, Mailwasher is pretty good at learning.
I have 3 laptops and 1 desktop around the house and se Good sync with a 320gb usb Hdd to syncronise each one by plugging into each one, using each folder as a different job and also gives me an external backup, I have just found Toysync from microsoft which i understand can sync over a wireless network but havent got round to trying yet so maybe an answer to get yours talking to each other, my setup may not suit everybody but it fulfills my needs. _________________ Moto G5s Plus, Sygic 17.4.8
Close the application completely and make sure that it is not running in the background. Assuming the program is installed in the "Applications" folder, launch Terminal ("Applications -> Utilities -> Terminal") and enter the command starting with / after the prompt in Terminal:
Adding -bin after the application name is necessary on some systems and application versions. If you have problems starting the Profile Manager with one of the above commands, try again using just the application name, as in this example for Thunderbird:
Posted: Wed Jul 28, 2010 10:33 pm Post subject:
aj2052, MaFt & Harry06, I haven't the faintest idea what any of you are talking about - I won't bother trying to do it with the MacBook. _________________ Dennis
