Pocket GPS World :: View topic - Nissan connect - won't load from memory stick
hadeedge
PostPosted: Fri Feb 05, 2010 10:06 pm    Post subject: Nissan connect - won't load from memory stick Reply with quote
After down loading the speed camera data as per your instruction on to memory stick then down loading it on to nissan connect it reckonises the download device then nothing. After searching your posts for a solution to this problem & trying various solutions still no not able to download. Looking at the download files the file I req does not end with .csv.. The file reads pocketgps_uk_sc there is no .csv at the end could this be the problem. Help would be much appreciated.
PostPosted: Fri Feb 05, 2010 10:35 pm    Post subject: Re: Nissan connect Reply with quote
That is probably just down to your settings in Windows Explorer on your PC. The file *is* named correctly, it's just that nice Mr Gates doesn't think you should see it.
To change the default view, go to the 'Tools' Menu at the top, select 'Folder Options', then the 'View' menu, and UN-TICK the box that says "Hide extensions for known file type."
Now you should see all the file extensions.
The above is the process for Windows XP, but I believe it's pretty similar for Vista/Win 7 if you have either of those.
I'm afraid I can't help with the actual problem you're having, if nothing in the other topics helps (you have added the extra space in the folder name (see HERE, for example?)
PostPosted: Sat Feb 06, 2010 1:23 pm    Post subject: Reply with quote
The link I gave above points to a topic where, as far as I can tell, it says you must ADD a space in the folder name between "my" and "POIs".
But to add further confusion to the matter, I've just received a PM from hadeedge saying:
To get it to load to the nissan connect I had to remove the space between myPOIs. The system shows that it has been been downloaded not tried it on the road yet hopefully everything should be ok.
So confusion reigns! Confused
22.062 (12 Jun 24)
