Pocket GPS World :: View topic - Speed Camera Database Now Available for Nokia N95 and others
AMWebby
PostPosted: Thu Jan 01, 2009 4:54 pm    Post subject: Reply with quote
I cannot get this to run. I get ErrNo-5 KerrNotSupported
Snoopydog
PostPosted: Fri Jan 29, 2010 10:54 pm    Post subject: Reply with quote
Hi people,
Can someone talk me through the process of making this appl. work on a Nokia E71, i have downloaded SpeedCam which although i can see in the installation folder on the phone i cannot open it, i am also then unable to load up the pocketgps_uk folder as i cant see where to put it!!
Help greatly appreciated.
Snoopydog
AMWebby
PostPosted: Fri Jan 29, 2010 11:47 pm    Post subject: Reply with quote
Snoopydog wrote:
Hi people,
Snoopydog
Assuming you've signed the application and have installed Python, make sure you install them both on the phone as they won't work from the memory card.
Then, once you've run the application there should be a Speedcam folder created on either your memory card or phone. Download the Pocket GPS Speedcam database, rename it speedcam.txt and upload it to that directory.
Snoopydog
PostPosted: Sat Jan 30, 2010 12:44 pm    Post subject: Reply with quote
Thanks AMWebby,
Application now loads up. I have loaded the PGPS database (i think) so are you able to tell me how to get Nokia Maps and speedcam working together as it seems to be either one or the other??
AMWebby
PostPosted: Sat Jan 30, 2010 1:00 pm    Post subject: Reply with quote
Snoopydog wrote:
Thanks AMWebby,
Have you got the latest Ovi maps? Version 3.0 provides free navigation.
You set Maps to load when Speedcam does in the Speedc am Perferences dialogue. First make sure the maps name is set to Maps, then choose "yes" for start Nokia Maps.
It doesn't seem to run as an overlay as it used to though. Sad
Snoopydog
PostPosted: Sat Jan 30, 2010 1:10 pm    Post subject: Reply with quote
Thanks AMWebby,
I have the latest maps for my phone (E71) and I have set it to start maps as sugested - it doesnt look like speedcam will overlay the maps as you say! pity
I will have to find a camera site to see if it works (none nearby)
AMWebby
PostPosted: Sat Jan 30, 2010 2:18 pm    Post subject: Reply with quote
It works great. I have uploaded my own sound files for mobile and fixed camera warnings and set it to only alert me if I'm over the limit of an approaching camera. Great stuff.
Snoopydog
PostPosted: Thu Feb 04, 2010 9:00 pm    Post subject: Reply with quote
Back again.
Finally found an area with fixed cameras but speedcam does not seem to work, any ideas anyone?
AMWebby
PostPosted: Thu Feb 04, 2010 10:12 pm    Post subject: Reply with quote
Snoopydog wrote:
Back again.
Assuming you have the speed camera database loaded correctly, it's probably set to only give you a warning if you are over the limit.
You can see this on the main screen, where it says All or Over on the bottom left of the screen.
Press the # key to toggle between:
Over (only alerted if speed is over camera speed limit)
o All (alerted whatever your speed)
Snoopydog
PostPosted: Fri Feb 05, 2010 1:55 pm    Post subject: Reply with quote
Hello AMWebby, thank you for your help here,
I am currently indoors with no signal and have a white screen with 'Speed' in top left corner, circle with black dot in middle, 'n/a' north of black dot, bottom right hand corner shows 'no signal' and 'fixed' and bottom right hand corner shows 'over'.
pressing the # key as suggested doesn't seem to do anything and looking at the other instructions on the speedcam guide the only things that work are my navigation key (left, right, up, down)
How do i tell if I have loaded the database correctly? Smile
AMWebby
PostPosted: Fri Feb 05, 2010 2:49 pm    Post subject: Reply with quote
You download the database file for Speedcam, rename it speedcam.txt and upload it to the speedcam folder Speedcam has created on your memory card.
From memory Speedcam won't start up without this file so I'm assuming you've completed this step successfully.
Your screen shows that Speedcam is set to give an alert only if you are over the speed limit for any given camera.
Remember on the E71 you must press the Function key in the lower left corner of the keyboard before pressing the # key, otherwise you're pressing the J key.
This should toggle Speedcam into All mode, where you will receive a camera warning regardless of your speed.
Snoopydog
PostPosted: Fri Feb 05, 2010 2:58 pm    Post subject: Reply with quote
What a numpty I am Embarassed clean forgot to use the function key, screen now shows 'all' in the bottom right hand corner - looks like it should work.
Need to find some cameras now..
Many thanks AMWebby
Snoopydog
PostPosted: Sun Feb 07, 2010 6:32 pm    Post subject: Reply with quote
I still can't seem to get this to work - drove past a mobile camera site, nothing happend!
I must have done something else wrong somewhere...
AMWebby
PostPosted: Sun Feb 07, 2010 7:32 pm    Post subject: Reply with quote
Assuming Speedcam is set to "All" and you've downloaded the "Nokia Speedcam" file from PocketGPSWorld, unzipped it and renamed the file called pocketgps_uk_master_and_pmobile.txt to speedcam.txt and uploaded that to the speedcam directory on your memory card all should work just fine.Currently Speedcam shows it has loaded 11272 speed camera records on start up. You should also make sure your E71 is set to use Assisted and Integrated GPS.
The only possibilities remaining is that the camera you are passing isn't on the database, which seems unlikely or that you haven't got a clear signal for GPS in your car. I have found my E71 works fine in my top pocket or in an open compartment in the central console of my car but does not work elsewhere. I have double glazed infrared glass on my car which blocks many GPS receiver, including TomTom, but the E71 works fine in these positions, not at all in any other, i.e in a side pocket of my jacket.
Snoopydog
PostPosted: Mon Feb 08, 2010 9:42 am    Post subject: Reply with quote
Thanks AMWebby,
I have a Brodit mount for the E71 and Nokia maps works just fine and also the speedcam loads up and shows the mph.
I have deleted and re-installed the current database to the Speedcam folder on my memory card (also contains scLang txt document, correct?)and checked to see what 'live' cameras are in my area (2 mobile sites nearby.)
Later on I will try to go past these camera sites to see what happens.
What other settings should I be aware of:
Proximity
Range/mph
etc.
It would be great to get this working and I guess I am doing something wrong here.
Thanks AMWebby for your help so far.
Page 3 of 4
22.062 (12 Jun 24)
