billws Occasional Visitor
Posted: Fri Dec 18, 2009 2:03 pm Post subject: Nissan Connect - problems downloading from site |
New user trying to download cameras for Nissan Connect system.All i get when i try to download is page after page repeating over and over again,no sign of where or how to download.
Can anyone HELP.I'm starting to loose patience now. |
Anita Pocket GPS Moderator
Posted: Fri Dec 18, 2009 2:30 pm Post subject: |
Welcome to the forum, billws.
I've just successfully downloaded and unzipped all three versions of the "Other - CSV" database, by using the "Download Speed Cams" link under "Speed Cameras" at the top of the screen.
Can you tell us exactly what you're doing and which version you're trying to download. _________________ Anita
TomTom VIA 135 - App 12.075
UK map 1130.12368
Samsung Galaxy S21 |
Posted: Fri Dec 18, 2009 2:41 pm Post subject: Nissan Connect |
Hi Anita,
Have tried your suggestion but when i go to "Download" i keep getting the same page over again.
Have tried several times but,,,same page telling me to download.
Its really doing mt head in,wish i'd never started in the first place
Bill. |
Posted: Fri Dec 18, 2009 2:42 pm Post subject: |
Looking at this more closely, I suspect you're not scrolling down the screen to the "Download Here" area, where you select your satnav system (or in your case "Other - CSV") from the drop-down box.
Come back and let us know if this doesn't solve your problem. _________________ Anita
UK map 1130.12368
Posted: Fri Dec 18, 2009 2:52 pm Post subject: |
Anita wrote: | Looking at this more closely, I suspect you're not scrolling down the screen to the "Download Here" area, where you select your satnav system (or in your case "Other - CSV") from the drop-down box.
Come back and let us know if this doesn't solve your problem. |
When i try to get "other csv files" i keep getting ERROR ON PAGE message showing.
This happens every time i try. |
Posted: Fri Dec 18, 2009 3:10 pm Post subject: |
I've just downloaded it again without any problems.
Just to confirm where it's going wrong for you, you're on the Download Database screen. You scroll down to where it says "Download Here", and selecting "Other - CSV" from the drop-down box, and clicking "Continue". You should get a screen with another drop-down box for selecting which version of the database you wish to download - I believe for the Nissan Connect you have to select "Single file with all cameras". At which point are you getting "ERROR ON PAGE"? _________________ Anita
UK map 1130.12368
Posted: Fri Dec 18, 2009 3:28 pm Post subject: |
Hi again,
Somehow i've managed to do it!
Am i right in placing all of the files which are a mix of bitmap and csv into the my/poi folder and then the csv files into the sub-folder called POI warnings |
Darren Frequent Visitor
Posted: Fri Dec 18, 2009 3:46 pm Post subject: |
The installation guide is here.
The files need to go into the x:\myPOIs\myPOIWarnings folder where 'x:' is the drive letter of your USB memory stick when inserted into your computer. _________________ Darren Griffin |
Posted: Fri Dec 18, 2009 3:53 pm Post subject: |
The instructions don't seem to tell you where to put the bmp file, Darren. I would have expected it to go into the x:\myPOIs\myPOIWarnings folder with the csv file. _________________ Anita
UK map 1130.12368
Posted: Fri Dec 18, 2009 3:55 pm Post subject: |
As far as we can establish, the Nissan system only requires the .csv file and uses its own Icon image.
I've corrected the install guide to remove reference to the .bmp files. _________________ Darren Griffin
Posted: Fri Dec 18, 2009 3:57 pm Post subject: |
Darren wrote: | The installation guide is here.
The files need to go into the x:\myPOIs\myPOIWarnings folder where 'x:' is the drive letter of your USB memory stick when inserted into your computer. |
Thank you all, it just needs to be tried in the car.Will let you know if it works.
Again many thanks.
Billws |
Posted: Fri Dec 18, 2009 3:59 pm Post subject: |
Darren wrote: | As far as we can establish, the Nissan system only requires the .csv file and uses its own Icon image. |
That explains it! Thanks, Darren. _________________ Anita
UK map 1130.12368
Posted: Fri Dec 18, 2009 4:32 pm Post subject: |
billws wrote: | Thank you all, it just needs to be tried in the car.Will let you know if it works.
Again many thanks. |
Glad you got there in the end, Bill. Let us know how it goes. _________________ Anita
UK map 1130.12368
Posted: Wed Dec 23, 2009 5:47 pm Post subject: Nissan Connect |
Many thanks to those who helped me to sucessfully download Safety Cameras and other POI's for my Nissan Connect system.
Special thanks to Anita who was so patient. Now that i know exactly how to do it, then i can now get more POI's as those pre-loaded onto the system are VERY limited.
Once again a big thanks to all involved.
billws. |
Posted: Wed Dec 23, 2009 6:13 pm Post subject: |
You're welcome, Bill. That's what the forum's for. We all help each other, and most problems are solved in the end.
You have found our free POIs here haven't you? _________________ Anita
UK map 1130.12368
