Pocket GPS World :: View topic - Will my GR-230 ever work on a XDA?
efbo
PostPosted: Thu May 20, 2004 12:42 pm    Post subject: Will my GR-230 ever work on a XDA? Reply with quote
HI,
I have a QTEK 2020 XDA with the following ROM:
ROM: 1.66.00WWE
ROMdate: 02/20/04
Radio version: 1.10.00
Protocol version: 1337.18
ExtROM version: 1.66.130
THis is a ROM with bluetooth upgrade. But I can't get my GR-230 to work. Ultimate goal is to get it working with TomTom3, but TomTom2 would be perfect in this stage!
Does anyone know what the proper steps and setup is for the device?
I did a hard reset and installed tomtom gpsdriver 2.07 which seams to be the most stable one. I tried with no connect. THe log i have shows the following:
$PTOM101,PocketPC,PH10B,2577,4.20*47
$PTOM102,GPS Engine,365,NMEA 0183v2 9600,COM5:*47
$PTOM103,040520,104557.000,040520,124557.000*36
$PTOM104,\My Documents\GPS Log\GPS20040520124557-busy.pgl*B
ààæ€àžæ††à€þ†àþààžàþ€žþàà˜€žžà˜˜†øà€ž€þžþàà˜þ憞†à†à†æ†à†à†à†ž†àøžþ˜†€†€†€†€†€†€†€†€†ø€€àà€àæøà憀þ€à€€€þàø††žææþà˜à˜à˜˜†ø憀†€˜àþààæ€àžæ††à€þþààžàþ€žþàà˜€æà˜˜˜à€ž€þžþàà˜þ†à†à†æ†ž†à†à†æ†ž†ž†àøžþ†€†††€†€†€†€†€†ø€€àà€àæøà憀þàà€€þþ€æþ††žææþà˜à˜à˜˜˜à†€†€˜àþààžæ††à€þ†þþààžàþ€žþààž€à˜˜˜à€ž€þžþàà˜þà†ž†ž†ž†ž†ž†à†à†à†àøžþ†€†€†€†€†€†€†€†ø€€àà€àæøà憀þà€þàž††žææþà˜à˜à˜˜˜†€†€˜àþààæ€àžæ††à€þžøþþààžàþ€žþààž€ø†à˜˜˜øà€ž€þžþàà˜þž†ž†ž†à†à†à†à†ž†à†àøžþ†€†€†€†€†€†€†€†€†€†ø€€àà€àæøà憀þàþà€€àþàþàþà††žææþà˜à˜à˜˜˜ø†€†€˜àþààæ€àžæ††à€þþø†þààžàþ€žþààž€˜àà˜˜ž†à€ž€þžþàà˜þ†ž†ž†ž†ž†à†à†à†à†ž†àøžþ†€††ø€€àà€àæøà憀þ€àþàþàþàøàþàþþ€˜††žææþà˜à˜à˜˜ž††þ†€†€˜àþààæ€àžæ††à€þþþààžàþ€žþààž€à˜˜žøà€ž€þžþàà˜þ†à†ž†ž†à†ž†ž†à†ž†ž†àøžþ€††€†€€àà€àæøà憀þ€à€àþà††žææþà˜à˜à˜˜žø昆€†€˜àþààžæ††à€þþ†àþààžàþ€žþàà˜€à˜˜žþà€ž€þžþàà˜þ†ž†ž†à†ž†à†ž†ž†ž†à†àøžþ€†€†€†ø€€àà€àæøà憀þààæàþà††žææþà˜à˜à˜˜žþ†€†€˜þ€þààæ€àžæ††à€þžþþààžàþ€žþàà˜€æþà˜˜àæà€ž€þžþàà˜þ†à†æ†ž†à†ž†à†ž†ž†à†àøžþ††††††€€àà€àæøà憀þàøàààøàøàààæàøàþàøàþàà††žææþà˜à˜à˜˜àæà†€†€˜þ€þààæ€àžæ††à€þþþ€æþààžàþ€žþàà˜€†øà
Is that correct? I dont think so, i assume it should be numbers.
I'm stunded, please help!!
Efbo.
lbendlin
PostPosted: Thu May 20, 2004 2:31 pm    Post subject: Reply with quote
Your BT receiver may have been set to SiRF protocol. Try using the setup program and switch it back to NMEA. Alternatively let the battery drain completely , this should do the same trick (but may take a week or two)
Lutz
TomTom/TeleAtlas NAVTEQ
efbo
PostPosted: Thu May 20, 2004 11:21 pm    Post subject: Reply with quote
Hi lbendlin, thanks for your suggestion.
I have a USB loader cable which is probably not the same as a data cable? I installed the drivers for the device on a Windows XP and Windows 2000 but both don't recognize the GPS.
How can I see from the output which protocol is on?
lbendlin
PostPosted: Fri May 21, 2004 12:02 am    Post subject: Reply with quote
NMEA is using pure ASCII and looks like this
$GPRMC,160339,A,3551.860,N,01430.858,E,000.0,360.0,030898,001.4,E*7D
$GPGSA,A,3,04,13,14,16,18,19,22,24,,,,,1.9,1.2,1.5*3E
$GPGSV,3,1,09,04,55,263,40,13,29,268,38,14,22,112,45,16,60,090,51*71
SiRF is binary and thus unreadable.
Lutz
