Pocket GPS World :: View topic - Help my Holux GPSlim 240 wont work
Hunterlaar
PostPosted: Sun Oct 28, 2007 3:18 pm    Post subject: Help my Holux GPSlim 240 wont work Reply with quote
It works if i plug it into the p.c but as soon as i take it out goes off also the green wire inside it is broke is this the wire that charges the battery?
philpugh
PostPosted: Tue Oct 30, 2007 1:34 pm    Post subject: Re: Help my Holux GPSlim 240 wont work Reply with quote
Sounds likely.
Is it obvious where the wire should be connected? If so - try soldering it back on. By opening it you have already invalidated any warranty your may have had on it Wink so it's worth a try as it is pretty useless as it is.
If the wire has broken off a circuit board it's usually possible to tell where it connected. Also the wire will quite often retain the shape it had when installed - so it's usually close to the end of the wire.
Phil
Hunterlaar
PostPosted: Sun Nov 11, 2007 4:34 am    Post subject: Reply with quote
There's no obvious place the wire goes uhmm oh well do you know if the holux M2000 is better than this one does it have longer life and better signal response? Thanks.
philpugh
PostPosted: Mon Nov 12, 2007 4:29 pm    Post subject: Reply with quote
Sorry - no experience of that device.
Phil
