dirtyburty Occasional Visitor
Posted: Sun Aug 26, 2007 6:39 pm Post subject: new member |
HI sorry you hav probably been asked this a hundered times, i hav a clarion Map670 and i cant get it to load camera software any help please.
many thanks chris |
alix776 Pocket GPS Moderator
Posted: Sun Aug 26, 2007 9:08 pm Post subject: |
it looks to be running iGO 2006 to add the camera loctaions connect the unit upto you PC make sure Activesync is installed you can get it from the microsoft website it you need to download it.
once the device is connected click the explore and then click the sd card.
go to the igo folder on the sd card and open it there you a file called poi open this then you will see a file called speedcam paste the txt file to there the close everything.
then disconect and soft reset the unit. now restart iGO now go to general in the set up menu and select alerts and enable camera waning you should now have speed amera warning on the unit _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Sun Aug 26, 2007 9:54 pm Post subject: |
hi tried that took out some software as told, put in text file as said checked map on pc for cameras then went to sat nav still not showing any cameras, what do you mean by soft start is that just turning on and off sat nav, it is igo software i have. many thanks chris |
Teddy_Bear Regular Visitor
Joined: Oct 25, 2006 Posts: 87 Location: warning have moved to leyland :D
Posted: Sun Aug 26, 2007 10:00 pm Post subject: |
On the unit press the reset buttom with the stylus to soft reset. _________________ truckdriver site www.truckerplace.eu
OFFICIAL PGPSW TEDDYBEAR |
Posted: Sun Aug 26, 2007 10:09 pm Post subject: |
many thanks thats got them will i have to do the same with mobile cameras on the other link, thanks again keep up the great work. |
