Pocket GPS World :: View topic - Btaudio.cab and Orbit
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Motorcycle GPS Users
sooty521
PostPosted: Sat Jul 14, 2007 9:52 am    Post subject: Btaudio.cab and Orbit Reply with quote
Hi All
Following a thread from Welsh Biker, i installed Btaudio.cab on my Orbit and it works fine until a phone call comes in, and then the sound reverts to the speaker. This happens even if i ignore the call!
Am I missing a setting, or do you need the Orbit in flight mode while using the Copilot and a Bluetooth headset?
Thanks for any advice
PostPosted: Sat Jul 14, 2007 11:45 am    Post subject: Reply with quote
Welcome to the forum, when you start the BTAudio application and set it to on are you using the minimise to tray option as this step is needed to keep the program working in the background - Mike
sooty521
PostPosted: Sat Jul 14, 2007 1:15 pm    Post subject: Reply with quote
Thanks for the welcome and prompt respone Mike
Yes I have minimised to tray, and on reading up a bit, it seems it is a common problem when calls are received?
Not too bothered about taking calls on the move, so may just gor for flight mode when using Copilot!
Will keep trying it out and let you know.
Chris
sooty521
PostPosted: Sat Jul 14, 2007 5:11 pm    Post subject: Reply with quote
No good, even when in tray, an incoming call, even if ignored, switches Copilot back to speaker. Definately hopeless on a motorcycle!!
If I switch to flight mode, the headset will not work at all!
Any ideas, or am I stuck with a wired headset, or having to buy a Zumo or TT?
Thanks again
PostPosted: Sat Jul 14, 2007 5:23 pm    Post subject: Reply with quote
Flight mode will switch off all radios (Phone, WiFi and BT) so flight mode is a waste of time, you could enable the BTAudio then switch off the phone in comm manager, this will stop the phone ringing messing up your audio when on the bike - and you did say you wern't too bothered about answering it anyway.
Once you get to the destination simply switch the phone back on - Mike
sooty521
PostPosted: Sat Jul 14, 2007 9:20 pm    Post subject: Reply with quote
Brilliant Mike, did not know you could just turn the phone off!
Hope it all works fine, as will save me a fortune in buying a dedicated Sat Nav
Thanks again
Chris
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Motorcycle GPS Users All times are GMT + 1 Hour
22.054 (22 May 24)
