Tinpusher Occasional Visitor
![](modules/Forums/images/avatars/18698510004516ab2452d02.jpg)
Posted: Mon Oct 16, 2006 5:36 pm Post subject: Multiple stop route planning |
I'm thinking of getting D6 to run on my Dell X51v (with a wired BR355 GPS).
What I want is to be able to plan routes to go to places via other places (a bit like delivery drivers might have to). As far as I know, most nav software only allows you to "go to" one destination.
Does D6 allow you to plan a route with multiple waypoints? And can you plan this on a PC and then upload it to the PDA, or does it have to be done on the PDA?
If D6 doesn't do this, what nav software does? _________________ Home - Dell Axim X51 + BT359 + D6 & MM
Work - IGI CCNS4, Vexcel Ultracam D & Somag GSM3000, X-Treme L1/L2 GPS receiver all shoved into a Piper Chieftain, registration G-OSGB. See the results on http://local.live.com/ |
Border_Collie Pocket GPS Verifier
![](modules/Forums/images/avatars/846718549526d5fd14b726.jpg)
Joined: Feb 01, 2006 Posts: 2543 Location: Rainham, Kent. England.
Posted: Mon Oct 16, 2006 6:16 pm Post subject: |
A combination of MS Autoroute and TTN5 allows you to set up multipul destinations/waypoints, optimise with Autoroute and save as an Itinerary with ITNConv to your PDA. _________________ Formerly known as Lost_Property
And NO that's NOT me in the Avatar. |
MarkP Occasional Visitor
Joined: 08/09/2002 10:45:31 Posts: 31 Location: United Kingdom
Posted: Tue Oct 17, 2006 10:10 am Post subject: Re: Multiple stop route planning |
Tinpusher wrote: | I'm thinking of getting D6 to run on my Dell X51v (with a wired BR355 GPS).
If D6 doesn't do this, what nav software does? |
Yes D6 does do this. It's within the extras section and called multistop planner; within that there are several options including add/delete/edit stops and route optimisation. |
Posted: Tue Oct 17, 2006 10:31 am Post subject: |
Excellent, thanks Mark. Sold! _________________ Home - Dell Axim X51 + BT359 + D6 & MM
mcewena Regular Visitor
Posted: Tue Oct 17, 2006 9:05 pm Post subject: Re: Multiple stop route planning |
MarkP wrote: | Yes D6 does do this. It's within the extras section and called multistop planner; within that there are several options including add/delete/edit stops and route optimisation. |
Yes but it's a little odd in that it doesn't attempt to compute the 2nd leg until you reach your first stop over. Which I guess is OK, just took me by surprise.
And if your route spans maps it doesn't display it correctly but I think it still works. |
