Pocket GPS World :: View topic - iPAQ5450 Bluetooth
iPAQ5450 Bluetooth
jellied
PostPosted: Wed Dec 31, 2003 1:02 pm    Post subject: iPAQ5450 Bluetooth Reply with quote
Just upgraded to WM2003 after a fashion. On the verge of buying a BT GPS unit and thought I would suss out the BT platform for the 5450.
I found this on the HP site:
http://h18007.www1.hp.com/support/files/HandheldiPAQ/us/download/19668.html
How does one tell if this is required or not? It is dated Nov. 03, I got my WM2003 disc early Dec., the version loaded is 1.4.1 (probably), the website claims to be 1.4.1.58
PostPosted: Wed Dec 31, 2003 2:56 pm    Post subject: Reply with quote
The easiest way is to initiate a bonding connection with a Bluetooth device, whilst you have the BT Manager screen open, power off the Pocket PC and see if it will power up. If it doesn't and requires a soft reset, then you need the patch.
DavidW
PostPosted: Wed Dec 31, 2003 7:33 pm    Post subject: Reply with quote
The version of the Bluetooth stack installed can be found using the About tab in Bluetooth Settings.
The original stack is Version 1.4.1 Build 06 on my iPAQ 3970. I can't tell you what version it is with the upgrade applied, as the upgrade hasn't been issued for the 3970 (I hope this isn't a sign of things to come and that HP will drop support for the 3900 series). I suspect it may be 1.4.1 Build 58 - but maybe someone could confirm that.
PostPosted: Wed Dec 31, 2003 8:37 pm    Post subject: Reply with quote
Interestingly I just checked my 2210 out and realised that although I had originally installed the upgrade I had done a hard reset and it had gone.
It reports my BT version as 1.4.1 Build 04 from WM2003 hardreset. However when I go to advanced it then reports the BTChooser.dll as version 1.4.1.04.
I then installed the BT driver upgrade and it now reports as being 1.4.1 build 58 and the BTchooser dll is 1.4.1.58.
Thanks David, I would have forgotten otherwise.
