fks123 Occasional Visitor
Posted: Sat Dec 20, 2003 6:09 pm Post subject: Rikaline X7 with Ipaq 5450 WM2003 TT 2 and TTGPS 2.08 |
hi there everyone,
my Rikaline X7 doesnt seems to work on with my Ipaq 5450...the SPP Slave can connect but somehow the GPS data doesnt comes throuhg as theres no clock runnig in the GPS screen and no dots moving...
and if i am lucky and it moves...it will only last for few seconds and it stalls and never moves again...
can anyone please help me out here ??
regards
sam |
Dave Frequent Visitor
![](modules/Forums/images/avatars/92698813943397cac09a13.gif)
Posted: Sat Dec 20, 2003 7:05 pm Post subject: |
Try switching to the NMEA 0183v2 4800 driver and see if this makes any difference. |
Posted: Sat Dec 20, 2003 7:15 pm Post subject: |
hi there Dave..
i have tried NMEA 4800 , 38400, and Bluetooth Driver. still no good..
it can sometimes work if i put it on Tomtom Wireless GPS...
when i use the winfast navigator it will says error opening com 8..
and theres an error that says counldnt find value whenever i tap port settings...
why is that so ??
thanks
sam |
Posted: Sat Dec 20, 2003 8:58 pm Post subject: |
I suspect it's a similar problem that many Bluetooth GPS manufacturers have experienced and that's the switching of protocols and baud rates at the same time unlinks the COM port inside the GPS from the Bluetooth. Although usually you can connect to the COM port, but you just receive no data.
I have an email open with Rikaline at the moment. |
hijacker Regular Visitor
![](modules/Forums/images/avatars/796487184490f720f0b6d1.jpg)
Posted: Sat Dec 20, 2003 9:06 pm Post subject: |
The best driver I found for this device was NMEA 155200, however......
Using an Ipaq2210, the X7 repeatedly locked up. From a soft reset and just loading GPS2.08 I could keep a connection sometimes for upto 20minutes.
Soon as I loaded TT2, GPS 2.08 would hang within seconds.
I've tried installing TT2 to ROM and a CF but it doesn't make any difference. Also have BT update installed from HP.
Totally disappointed. |
Posted: Sun Dec 21, 2003 2:15 pm Post subject: |
well...mine doesnt work if i put it on NMEA 4800, 38400 or 115200..
no dots moving and no clock at all...
but when i put it on Tomtom Wireless GPS..
at least there are dots moving for 2 seconds and clock counting...
but then immediately stalls after few seconds...
any one have any idea ???
i think my Rikaline is the newer version(thats what i was told)
i used to have a unit that has yellow LEDS but was replaced by a unit which i am now using . it has Blue LEDS...
thanks
sam |
Phreakster Occasional Visitor
Posted: Mon Dec 22, 2003 7:22 pm Post subject: |
Install Tom Tom 2 GPS 2.08 and then select Rikaline 6010 and have Com 8 selected. Works fine for me ;) |
Posted: Tue Dec 23, 2003 1:56 pm Post subject: |
hi there...
i had tried the Rikaline 6010 on bluetooth com 8...
it connected for 2 seconds and the 'dots' stalled and clock will not move anymore....
any idea whats wrong ??
my connection is always not stable.....it tends to hang in very short time...
regards
sam |
Posted: Tue Dec 23, 2003 2:02 pm Post subject: |
It sounds like you probably have the 6012. |
Posted: Tue Dec 23, 2003 9:19 pm Post subject: |
hi there Dave..
but my receiver is the Rikaline 6031 X7 bluetooth receiver...
i had tried many times connecting with Rikaline 6010 drive at Bluetooth Com 8....
i had succeded once without it stalling...and got satelite and my postition track while sitting in my room upstairs...once i run from my room ..downstairs and out of the house...the 'dots' stops moving and the clock stalls...
i have also got a reply that says that his Rikaline X7 works fine on ipaq 3970 with WM 2002...
anyone can solve the problem of my X7 keep stalling ??
is it the receiver's problem or the Tomtom software problem ??
regards
sam |
Posted: Tue Dec 23, 2003 10:16 pm Post subject: |
Dang, I replied to the wrong thread.
There are some issues currently with X7's. Connecting using the Emtac Wireless driver should get you up and running AFAIK, but Rikaline have confirmed they do have problems with the X7's where suddenly data stops flowing (keeps stalling). Rikaline are currently working on a fix for this (hopefully it will just be a firmware update, but might be more serious). Interestingly enough Rikaline have also been having problems with their 6012's, it does seem that QA isn't one of Rikaline's best features. |
Posted: Fri Dec 26, 2003 1:30 pm Post subject: |
An easy thing to test whether its the software or hardware is to get another piece of gps software such as GPS Tuner and see how the reciever behaves with that.
If you get the same results then you could have a duff rikaline reciever. But it seems to work great with my 3970. |
