Ash10 Pocket GPS Verifier
![](modules/Forums/images/avatars/766726342477fdefb3500b.jpg)
Posted: Mon Jul 17, 2006 7:47 pm Post subject: Ash10's Camera Manager Software |
I've been busy writing some new software - it's called Camera Manager, and here it is:
LINK TO LATEST VERSION
When you run Camera Manager, it installs itself in the system tray - in this case, next to the clock:
Camera Manager doesn't just sit there, oh no! Once a day, it checks to see if there is an update available to the PocketGPSWorld.com speed camera database.
If there is an update available, Camera Manager automatically downloads it, saves it to your POI directory, unzips the contents, and tweaks the files to give time warnings (rather than distance warnings).
Once it's done all that, Camera Manager politely lets you know that the update is ready for downloading to your Garmin device using POI Loader.
Camera Manager will continue to periodically remind you to update your Garmin device, until you do so using POI Loader.
Note that you will need to be logged in to PocketGPSWorld.com in order for Camera Manager to check for updates. This needs to be done using Internet Explorer , although once you've logged in with IE you can go back to using Firefox etc.
If you're not logged in to PocketGPSWorld.com, Camera Manager can't check for updates, and it will let you know accordingly:
Right-clicking on the icon will make Camera Manager repeat the last message bubble ;)
Left-clicking on the icon will open the Settings window:
The warning time settings work pretty much as before - you can either type a value directly, or use the adjuster arrows to change the existing value.
The current version of the PocketGPSWorld.com speed camera database is displayed, as well as the time and date this was last checked, and also shown the working directory used by POI Loader.
Clicking the Cancel button will close the Settings window, discarding any changes that have been made.
Clicking the OK button will close the Settings window, save the current settings, and if any changes have been made - re-tweak the files and prompt you to update your Garmin unit once again.
Clicking the Quit button exits Camera Manager completely - this is important, because clicking on the Close (X) icon or pressing Alt-F4 will only close the Settings window.
Note that Camera Manager is a persistent application - when run, it sets itself up to be run automatically following the next computer restart. To stop this, simply exit using the Quit button described above.
Please remember that this is currently beta - comments, suggestions, or bug-reports are most welcome... ![Smile](modules/Forums/images/smiles/icon_smile.gif)
RODTROTTER Regular Visitor
![](modules/Forums/images/avatars/gallery/avatar_ani_015.gif)
Posted: Mon Jul 17, 2006 10:07 pm Post subject: |
it looks very good i will install it to test |
Posted: Mon Jul 17, 2006 10:24 pm Post subject: |
Excellent - seems to be working here.....
8) |
Posted: Mon Jul 17, 2006 10:25 pm Post subject: |
not working for me keeps shuting down i think i try a restart |
Posted: Mon Jul 17, 2006 10:36 pm Post subject: |
OK. Downloaded, ran Camera Manager, it downloaded latest Camera files and converted to GPX and reported ready to upload.
Then i noticed the timings where not set to the same values as the old Camera Updater software i used previously, so i adjusted them and deleted the new GPX files and database download. However i now can't get Camera Manager to redownload the database and run it thropugh your software to generate new GPX files based on the new timings i selected.
It keeps reporting Last Checked: Monday, July 17, 2006 - 21:31:46 even though i have closed and re-started the Camera Manager several times. It's now 21:50... |
Posted: Mon Jul 17, 2006 10:42 pm Post subject: |
PaulB2005 wrote: | Then i noticed the timings where not set to the same values as the old Camera Updater software i used previously, so i adjusted them and deleted the new GPX files and database download. However i now can't get Camera Manager to redownload the database and run it thropugh your software to generate new GPX files based on the new timings i selected.
It won't re-download the database, because you already have the lastest version downloaded! ;)
Quote: | Clicking the OK button will close the Settings window, save the current settings, and if any changes have been made - re-tweak the files and prompt you to update your Garmin unit once again. |
zogman Frequent Visitor
![](modules/Forums/images/avatars/4129001634330026455503.gif)
Joined: Sep 05, 2005 Posts: 1417 Location: swindon uk
Posted: Tue Jul 18, 2006 8:44 am Post subject: |
thanks ash..i think we are very lucky to have someone with your skills on this forum.... ![Clap](modules/Forums/images/smiles/div348.gif) _________________ *************************** |
Posted: Tue Jul 18, 2006 9:30 am Post subject: |
Quote: | It won't re-download the database, because you already have the lastest version downloaded! |
Even if i delete the database it downloads it still won't do it again.
I did see that however i can't see any new GPX files being created. For example if i create a set at 9:00 and i then change the settings at 9:300clicking ok doesn't produce new GPX files or update the old ones (at least the time stamps don't change from 9:00.
Perhaps i'm missing something but the first time i saw a database file had been downloaded and then a set of new GPX files appeared. Then i changed the settings and deleted the database file but it never attempts to downlaod the database file again or create new GPX files.
Quote: | thanks ash..i think we are very lucky to have someone with your skills on this forum.... |
Very true. I wish i had just 10% of Ash10's talent. |
Posted: Tue Jul 18, 2006 9:52 am Post subject: |
PaulB2005 wrote: | Perhaps i'm missing something but the first time i saw a database file had been downloaded and then a set of new GPX files appeared. Then i changed the settings and deleted the database file but it never attempts to downlaod the database file again or create new GPX files. |
Er, why did you delete the database file?! It won't be downloaded again until PGPSW release the next version...
Undo the delete and restore the database file from your Recycle Bin 8) |
Posted: Tue Jul 18, 2006 10:01 am Post subject: |
Quote: | Er, why did you delete the database file?! It won't be downloaded again until PGPSW release the next version...
Undo the delete and restore the database file from your Recycle Bin |
Testing the software as asked..... Quote: | comments, suggestions, or bug-reports are most welcome... |
Now i deleted the file to see if i could make it re-generate the GPX files (i.e. make it think it hadn't been run yet) I'm still stuck with the first set of GPX files it made after it was first run which have the wrong values in them. Subsequnet runs don't seem to be able to generate new upadted GPX files.
I can't see how to get the software to re-generate the GPX files if i decide to change the values after i've run the software once. |
Posted: Tue Jul 18, 2006 10:08 am Post subject: |
PaulB2005 wrote: | Now i deleted the file to see if i could make it re-generate the GPX files (i.e. make it think it hadn't been run yet) I'm still stuck with the first set of GPX files it made after it was first run which have the wrong values in them. Subsequnet runs don't seem to be able to generate new upadted GPX files. |
You won't be able to regenerate the GPX files, because the source data (ie: the downloaded camera database) has been deleted.
As mentioned in the instructions, the GPX files are regenerated if you change any of the timing settings and subsequently click on the OK button. |
Posted: Tue Jul 18, 2006 10:19 am Post subject: |
Doh! Solved it. My idiocy......
I had put the download back (i didn't make this clear - sorry)
However it now works - well at least i can make it work as it was never broken. I think the problem was i wasn't actually changing the values!!! Difficult to explain but I'll try. I was changing the values but it appears that due to my indecisiveness over what timings i use / used it appears i was just setting the same timings over and over - hence no new files. Just now i changed all values to 60 seconds and it generated the new files.
Sorry.
Great software BTW. |
nudda Regular Visitor
Posted: Tue Jul 18, 2006 10:29 am Post subject: |
Dont need this now but awesome ! Well done and thanks for putting in the hard work for us 8) |
trevf Regular Visitor
![](modules/Forums/images/avatars/gallery/avatar_ani_001.gif)
Posted: Tue Jul 18, 2006 10:55 am Post subject: |
Well done Ash, seems good to me.
One question though...
As a Firefox user I really like to avoid using IE as much as possible. Do I need to log into PocketGPSWorld.com every time using IE or will a one off and save password do it?
Also as a feature request, could you include a checkbox (and related download code) to get the POIs from Mafts Site? _________________ Garmin i3
Firmware 3.4 |
Posted: Tue Jul 18, 2006 11:08 am Post subject: |
trevf wrote: | As a Firefox user I really like to avoid using IE as much as possible. Do I need to log into PocketGPSWorld.com every time using IE or will a one off and save password do it? |
Your in good company, there! ;)
Just use IE to log in to PGPSW once, don't log out, then don't ever touch IE again - even with someone's else's bargepole... 8) |
