Pocket GPS World :: View topic - Meridian external power power supply.
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Magellan
Wook
PostPosted: Mon Oct 06, 2003 2:08 pm    Post subject: Meridian external power power supply. Reply with quote
Hi all,
I am thinking of rigging up an external power supply for my Meridian, and as the cheapskate that I am I can't be bothered to buy the 12 volt power adaptor, especially as I already have a spare data cable which I hope will be easy to convert into a power cable. I have 2 question?
1) Does anyone know is the data cable also includes the power wire, i.e. if I cut the insulation off will there be four wires there - data in, data out, ground, and power. But only the three wires will be connected to the end serial connector?
2) What is I the little black power supply box on the power cable you can buy. I assume its some kind of mechanism to reduce the voltage down to 3 volt.
I don't hold out much hope that anyone will randomly know the answers to this, but you can but ask!
Cheers, Wook
GPS_Chan
PostPosted: Mon Nov 10, 2003 11:18 pm    Post subject: Reply with quote
for question 1 I dont' think so it included power cables.
for question 2 I believe u guessed right.
just to add, u need total 4 for power, and data. power need to be ground.
Let us know how it turned out. Smile
Mika73
PostPosted: Wed Apr 21, 2004 11:10 pm    Post subject: Reply with quote
You need that black box. One time something 'funny' happend on my car and voltage did get as high as 32 volts.. I guess that black box can save your GPS. Atleast manual says that if you remove it your Meridian will damage.
fanatix
PostPosted: Sat May 27, 2006 3:51 pm    Post subject: Reply with quote
did you tried it? to cut the ropes? I'm also planning doing it, but i'm not sure about the power cable in the data cable....
else I would damage the two cables...
yearnslow
PostPosted: Sun Jul 02, 2006 2:42 pm    Post subject: Reply with quote
hope you got all that wook? :D
arthurking83
PostPosted: Sat Jul 22, 2006 9:41 am    Post subject: Reply with quote
Yellow wire = data in
Orange wire = data out
Red wire = power +ve
Black wire = ground/power -ve
Data cable will only have the two wires,
There is no reason not to run a second cable along the data cable and modify the connector (GPSr end) to accept power.
you could somehow modify that connector to have two protruding metal power contacts. (the connector itself may be impossible to modify without cutting/drilling.
I purchased two 'dead' power/data leads off ebay, just for the connectors and wires, and bypassed the black-box that magellan used (the dead component)
I just run a good quality power supply, just make sure that it supplies a good regulated 3.6volt output!! Mine runs at about 3.5v, for over a year without any problems now :D
there is more info at the Meridian Yahoo group
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Magellan All times are GMT + 1 Hour
22.054 (22 May 24)
