Pocket GPS World :: View topic - old tracker
old tracker
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Magellan
Fishy
PostPosted: Thu Dec 04, 2003 5:55 pm    Post subject: old tracker Reply with quote
i'm new here .. hope you can help !
I've got a Magellan Tracker from about 6 years ago, and i run memory map software with it on my laptop for off roading - but it's time to upgrade .. Can you buy a lead that will hook up the Tracker (older style connector on the back arranged in the round) to an Ipaq 2210 ?
And can anybody then suggest a street navigation software for on road, keeping the memory map software for my off roading ?
PostPosted: Sun Dec 07, 2003 9:50 am    Post subject: Reply with quote
I haven't seen an older Magellan connector, only the current style connector on all the latest Magellans. If this is the case, then you should still be able to use it on an iPAQ but will probably require a serial lead for the iPAQ, and perhaps a gender bender to change from female to male (vice versa) one end of the cable and also a null modem adapter. In theory I can't see any reason why this wouldn't work.
Failing that if it's a standard Magellan connector like below
Then you could purchase a GMQ38 from http://www.pc-mobile.net/maggps.htm
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Magellan All times are GMT + 1 Hour
22.054 (22 May 24)
