Pocket GPS World :: View topic - Downloading the speed camera database into Destinator 6
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Destinator
mark1968
PostPosted: Sat Jun 10, 2006 11:23 am    Post subject: Downloading the speed camera database into Destinator 6 Reply with quote
You will need to have the .csv version of the database.
This can be achieved by download.
In my case I down loaded the TOMTOM speed zoned files and then used the utility Poi Edit to change the file format.
To install into Destinator firstly copy the .bmp icons from your PC onto your PDA into the following location: \DestinatorApps\Destinator\UserData\Favorites
Then open the Destinator console on your PC.
Select Import Favourites
Select the first .csv file and click on convert. The console then confirms how many records have been loaded.
Then click on Download.
After the console application has finished its file copy, open Destinator your PDA.
Go into the Favourites option and you should see the new groups listed showing the correct icons.
Select the Favourite group that you wish to have alerted and shown on map by placing a tick in the box to the left of the group name.
Then click on Alerts and a screen will show asking to set the 1st and 2nd Alert Distances. Make your selection and click on done.
If you find that the correct icon is not showing next to the group try the following:
Click on Actions.
A new screen will be displayed. Select Edit Group. Then select the correct icon on the top line and click on save.
I am now sure if this process works on an PNA device as I do not have one to hand.
Please follow me on twitter @mdyson1968
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
Oldboy
PostPosted: Sat Jun 10, 2006 4:04 pm    Post subject: Re: [b]Downloading the speed camera database into Destinator Reply with quote
Why not Select 'Other' in the SatNav Drop Down List, then you will be presented with the Option to Download in CSV Format.;)
uniuk2000
PostPosted: Mon Jun 19, 2006 9:15 pm    Post subject: Reply with quote
Thanks Mark, I was wondering how to do this as I'm new to Destinator. I do get a problem though. When I load a .csv file into the favorites importer and click on 'convert' I get the report 'No Data'. I'm using the downloades speedzoned .csv files. Any ideas what might be going wrong.
Thanks in advance.
Regards
mark1968
PostPosted: Tue Jun 20, 2006 5:22 pm    Post subject: Reply with quote
Thanks in advance.
I had the same error when using a csv file downloaded from this site. I did not have this error when converting the .ov2 files into .csv via POI Edit.
mark1968
PostPosted: Tue Jun 20, 2006 5:23 pm    Post subject: Reply with quote
Thanks in advance.
sHaRpEy
PostPosted: Fri Jun 23, 2006 1:24 am    Post subject: Reply with quote
Thanks for this, worked a treat after I "found" the database update on the net somewhere Rolling Eyes Laughing
uniuk2000
PostPosted: Sat Jun 24, 2006 6:23 pm    Post subject: Reply with quote
I've got it sorted now, had to use the single file download from here and it worked ok. Maybe it's something to do with the small size of the individual files in the speed zoned version??
meestermartinho
PostPosted: Wed Jul 19, 2006 12:20 pm    Post subject: Reply with quote
Does desinator 6 still take an age to load when the speedcameras are in it?
TheRock
PostPosted: Wed Jul 19, 2006 2:01 pm    Post subject: Reply with quote
No.
This is solved since the PN 5.1.172 Update/patch.
D7
loox n500
sailorman
PostPosted: Wed Nov 08, 2006 6:48 pm    Post subject: Re: Downloading the speed camera database into Destinator 6 Reply with quote
This worked well on an Asus MyPal A636N - which is effectively a PNA.
shifty136
PostPosted: Mon Mar 05, 2007 1:37 am    Post subject: Reply with quote
works a treat, thank you
chizler
PostPosted: Tue Mar 13, 2007 10:36 pm    Post subject: detinator 6 Reply with quote
I am also having trouble loading my speed cameras onto my Acer n35 PDA detinator 6 loaded ok but the speed cameras do not work, can anyone help?.
Chizler
chizler
PostPosted: Thu Mar 15, 2007 10:02 pm    Post subject: Re: detinator 6 Reply with quote
chizler wrote:
I am also having trouble loading my speed cameras onto my Acer n35 PDA detinator 6 loaded ok but the speed cameras do not work, can anyone help? soon.
Chizler
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Destinator All times are GMT + 1 Hour
