Pocket GPS World :: View topic - Dialing from Outlook
Bisto
PostPosted: Fri Nov 14, 2003 12:08 am    Post subject: Dialing from Outlook Reply with quote
Is it possible to dial a number from contacts in outlook which will be sent via Bluetooth to a dial up on a Nokia 6310i ?
PostPosted: Fri Nov 14, 2003 7:21 am    Post subject: Reply with quote
Yes it is, there are various GSM based applications available for the Pocket PC that will allow you to do this and also send text messages from the Pocket PC via the mobile.
Try searching for GSM at www.handango.com
alix776
PostPosted: Sat Nov 29, 2003 6:33 pm    Post subject: Reply with quote
if you have a 2210 on ppc 2003 it should do it allready out of the box tap hold the contact then tap the bit marked dail via blue tooth and there you go Thumbs Up
device Lumia 950 xl
