Pocket GPS World :: View topic - PDA-Tool: Favourites sorting by distance
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Destinator
Jonisinimo
PostPosted: Sat Mar 18, 2006 11:28 pm    Post subject: PDA-Tool: Favourites sorting by distance Reply with quote
DPN is able to sort POI's in alphabetic and distance order.
But in this version DPN is not able to sort favourites by distance.
I have written a little tool (running on the PDA) that sorts the favourites by distance.
In the german version this tool is running since august last year.
I am not able to read the current position from DPN (while DPN runs).
Therefore i have choosen following way:
I create within DPN the current position by storing it in the favourit "My favorites".
Installation of the program:
Copy the file on the PDA and start it.
Requirements:
- .NET Compact framework must be installed
(for Pocket PC 2003 it is already installed by default)
Procedure:
- select the favourite which should be sorted by distance
- then choose the reference position (by default stored in "My favorites")
- select the radius (default 60Km)
- click on start button
- now the program reads the choosen favourite and calculates the distance of every object in this favourite to the choosen reference position
and write the objects with distance in a new favourite.
The new favourite has the same name but with the prefix #.
Creating the reference position within DPN:
- on the map within DPN choose a reference position by tipping on that position
- in the context menue select favorite
- store the reference positon in "My favorites" with any name (example name: "John Public")
The folder name of the DPN favourites and the name of the favourit in which the reference position is stored (default: "My favorites") are stored in a file called FavoritenPfad.ini.
This file will be created in the root directory after first start of the program.
The file is a text file and can be edited to change the data but it is easier to change it in the program itself under the menue item "options".
Example for an objectname:
Original (before): John Public
Output with distance (afterwards): 023Km-John Public
You can download the program at following adress:
http://www.pocketnavigation.de/board/thread.php?postid=661039#post661039
the english version is called "Favorite_sorter_v1.1e.zip"
alanf
PostPosted: Fri Apr 07, 2006 12:25 am    Post subject: Excellent program Reply with quote
Excellent program, thanks mate.
alanf
PostPosted: Fri Apr 07, 2006 12:29 am    Post subject: Re: Excellent program Reply with quote
Forgot to add, it works just as you describe on my Acer n35/ Destinator v3.0.75 kit.
koom
PostPosted: Tue Jan 02, 2007 2:10 am    Post subject: Reply with quote
Is there a version for Win CE 4.2 (for Acer D100)?
koom
PostPosted: Tue Jan 02, 2007 1:33 pm    Post subject: Reply with quote
I tried on Win CE and it works just fine. But the buttons aren´t visible.
Who's the author of the program? Can i get the source code...? I could make the adjustments... Or if the author could just that...
Thank's
allmen
PostPosted: Wed Jan 03, 2007 4:09 pm    Post subject: Reply with quote
Tried to get this to work on Destinator 6 but must be doing it wrong as I cannot get the places to show in the box. Installed in Favorites and it does open but only to show pick a favourite where there is nothing. Anyone help perhaps something else is needed to let it work in Des6
Acer N35
Destinator 3
Destinator 6
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Destinator All times are GMT + 1 Hour
