Pocket GPS World :: View topic - Strange prob/bug TT5 Nav
getsurfers
PostPosted: Thu Jan 05, 2006 11:46 pm    Post subject: Strange prob/bug TT5 Nav Reply with quote
Running TT5 v5.21 on Dell x5, PPC 2002.
This prob started after driving along the M4 to London and the map went fuzzy. TT5 locked up, and I had to do a soft reset to get the PDA to do anything.
Since then, periodically, there is a strange issue with the screen. The screen will not display the menu when tapped, but instead splits the screen left/right all the way up.
So press the left anywhere, and you get volume setting. Anywhere on right side and you get the route screen. But if you go into the route screen, the screen works normally. Exit back out to nav or if you leave it until a recalc or instruction is given, everything goes back to normal. It also happened ONCE in Excel, but the TT 'hand' logo was still on the bottom, soon as TT went all was normal.
Apart from the crash, and a few excel file edits, no changes to the system to indicate a cause.
Anyone else heard of this either with TT or PPC???? It's driving me mad!
Peter Kessler
PostPosted: Fri Jan 06, 2006 2:41 am    Post subject: Reply with quote
I think I have had the same or similar problem with my hp rx3715. The screen goes fuzzy and then simply fades away to white. If I soft reset quickly then I get everything back ok, but if I leave it in white-out for more than a few seconds then I have to do a total hard reset. Is this similar?
andy-c1
PostPosted: Fri Jan 06, 2006 10:08 am    Post subject: Reply with quote
or have you tried a hard reset ,and restore ,it could be the ppc & not tt .....but i could be wrong
TomTom 5001
getsurfers
PostPosted: Sun Jan 08, 2006 10:49 pm    Post subject: Reply with quote
Tried re-install and reset, but still happening.
Have noticed another way to get it to come back to life when this happens - remove from the TT x5 cradle.
Confused
22.054 (22 May 24)
