Pocket GPS World :: View topic - Dell Axim X50v & Garmin GPS 10 - Que doesn't see GPS?
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Garmin Handheld GPS Receivers
Rambler358
PostPosted: Sun Aug 07, 2005 1:20 am    Post subject: Dell Axim X50v & Garmin GPS 10 - Que doesn't see GPS? Reply with quote
I've recently upgraded from the Garmin cf Que 1620 to the Garmin GPS 10. The Que software seems to be identical for both. I've got the GPS 10 paired via Bluetooth just fine, and I can establish a connection with the GPS from my PDA also just fine. However, Garmin's Que software doesn't see the GPS 10 unit. The PDF documentation indicates that there's a Interface tab under the System Settings, but I'm not seeing it. Confused I've upgraded to the GPS 10 Que software v2.70, but it doesn't make a difference - I don't see any Interface tab to try and set the GPS. Any ideas? Question
Ron
tcassidy
PostPosted: Tue Aug 09, 2005 3:21 am    Post subject: Reply with quote
Load the new software that came with the GPS 10. Then you will have the interface tab.
Terry
Garmin eMap,SPIII,GPS18 PC,cfGPS1620,GPS10
Toshiba E800SE
Rambler358
PostPosted: Tue Aug 09, 2005 6:58 pm    Post subject: Reply with quote
Terry
Unfortunately, loading the software that came with the GPS 10 doesn't fix the problem. Sad
I contacted Garmin, and they mentioned that the cf Que leaves some errant registry entries on some PDAs even when it's un-installed. They e-mailed me a utility that fixed the issue, and it's working great now.
The GPS 10 receiver acquires a 3D position *much* faster than the cf Que did, and I'm quite happy with it now. Another plus of the GPS 10 is that you can use other mapping software with it as well. I'll be receiving my TomTom Navigator 5 update shortly, so it'll be interesting to see how it works with that.
Ron
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Garmin Handheld GPS Receivers All times are GMT + 1 Hour
