Pocket GPS World :: View topic - just a few questions ??
vestax
PostPosted: Thu Jul 07, 2005 10:47 pm    Post subject: just a few questions ?? Reply with quote
first off i've tried loading the speed camera database and it just crashed my ttg 300 so i guess the standard card is to small.
what card do you recomend (size / make)
after downloading the pocket_uk_sc files, which .ovc/.bmp files do i copy? as there are quite a few in the different folders.
what is the single files .ovc's for? and do i have to load the voices files up aswell?
and what is all the different logo's?
i'm confused
PostPosted: Thu Jul 07, 2005 11:29 pm    Post subject: Reply with quote
Have you read the instructions here?
PostPosted: Fri Jul 08, 2005 6:19 am    Post subject: Re: just a few questions ?? Reply with quote
i'm confused
There can be 3 setups for speed cameras.
The first is a single file that contains all the cameras together, without any reference to what type. This is named pocketgps_uk_sc.ov2 and found in the 'single file version' folder.
Second is the 5 file version that divides the cameras into types. Gatso, Mobile, Specs, Redlight and Temporary. These you will find in the 'ov2 bmp' files.
Third is the full 13 file version that divides the Gatso and Mobile files into speed zones. There are 7 each of the Gatso and Mobile files. These are found in the 'speed zoned/gatso/ov2 bmp' and speed zoned/mobile/ov2 bmp' folders. Add to these the Specs, Redlight and Temporary files as above.
I have not included the Continental file because you will only need this if going to the continent.. But should you want it , it's in the 'ov2 bmp' folder.
When you've decided which set you want copy each .ov2 file, and it's matching .bmp file to your map folder. Then setup the POI's in Manage POI.
You should have enough memory if you delete unused instruction voices. Each one uses about 1MB.
