cocacola186 Lifetime Member
Posted: Wed May 10, 2023 8:21 pm Post subject: hgv satnav |
i am looking at getting a hgv satnav it must be able to get the pgpsw speedcam database on it and other custom poi. what do you reccomend pls |
Kremmen Pocket GPS Verifier
Posted: Thu May 11, 2023 4:59 am Post subject: |
Has to be a Garmin _________________ Satnav:
Car Average MPG :
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15155 Location: Bradford, West Yorkshire
Posted: Thu May 11, 2023 11:12 am Post subject: |
Yep - definitely a Garmin. I know they do specialist HGV ones where you can input your width/height etc and it'll give you suitable routes (they're more expensive than car satnav's due to the extra data needed in the mapping)
Garmin are also one of the few remaining manufacturers that haven't blocked users from adding their own POIs and Speed Camera data etc.
Garmin's Truck range is here: https://www.garmin.com/en-GB/c/automotive/semi-truck-gps-navigation/ |
Posted: Thu May 11, 2023 7:10 pm Post subject: |
MaFt wrote: | Yep - definitely a Garmin. I know they do specialist HGV ones where you can input your width/height etc and it'll give you suitable routes (they're more expensive than car satnav's due to the extra data needed in the mapping)
thanks for that info much appreciated so i will be able to add the pgpsw speedcamera warnings on to the dezl lgv610 model.? |
Posted: Fri May 12, 2023 3:56 am Post subject: |
We cannot be 100% sure but I think we can be 99% sure.
I've never yet come across any Garmin SatNav that hasn't allowed the PGPSW database to be loaded and work as intended.
Just follow the 'spoon feed' tutorial or use my CSV to GPX Converter if you want more control over alerts timings.
Both are stickies in the Garmin section. _________________ Satnav:
Car Average MPG :
Posted: Fri May 12, 2023 9:26 am Post subject: |
I've found the manual online for the Dezl LGV610 and you can add Custom POIs using POILoader and these can contain speed alerts. I.e. - yes, it is compatible.
MaFt |
Posted: Sat May 13, 2023 8:43 am Post subject: |
MaFt wrote: | I've found the manual online for the Dezl LGV610 and you can add Custom POIs using POILoader and these can contain speed alerts. I.e. - yes, it is compatible.
MaFt |
thankyou for your help. |
