RODTROTTER Regular Visitor
Posted: Fri Sep 28, 2012 7:48 pm Post subject: spoken speed cam warning |
can you get a spoken speed cam warning on garmin like you can on tomtom
just put on cam data base getting a bong warning and thats it even though i downloaded and put on voice files any ideas ? iam not very good with garmin only got it for the life time map updates |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10641 Location: Suffolk, UK
Posted: Fri Sep 28, 2012 9:36 pm Post subject: |
If you do a Search for poiloader sox.exe, there are numerous Topics on the subject. I'm sure one of them can point you in the right direction better than I can. _________________ Richard
Posted: Mon Oct 01, 2012 6:58 pm Post subject: |
ok put the sox.exe in the install folder of the poi uploader have tried the spoken warning as mp3 did not work now will give the waw files a go in the garmin settings for poi warning what do i need to put it on for this to work ?
single tone continuous tone or off ? |
walkerx Lifetime Member
Joined: Oct 21, 2009 Posts: 491 Location: South Yorkshire
Posted: Mon Oct 01, 2012 11:12 pm Post subject: |
RODTROTTER wrote: | ok put the sox.exe in the install folder of the poi uploader have tried the spoken warning as mp3 did not work now will give the waw files a go in the garmin settings for poi warning what do i need to put it on for this to work ?
if you only want to be reminded once then single tone, otherwise continuous tone
mp3 format won't work on the garmin, so you must use the wav files |
Andy_P Pocket GPS Moderator
Posted: Tue Oct 02, 2012 1:03 am Post subject: |
walkerx wrote: |
I thought the rule of thumb was "if the Garmin has an mp3 player, then use the mp3 voice files. If not, use the .wavs" _________________ "Settling in nicely" ;-) |
Posted: Tue Oct 02, 2012 9:11 pm Post subject: |
Andy_P wrote: | walkerx wrote: |
I thought the rule of thumb was "if the Garmin has an mp3 player, then use the mp3 voice files. If not, use the .wavs" |
most of the latest garmin devices do not support mp3 playback - so unless OP can advise which version they have I would still say not supported and must use wav files.
i got told originally that mp3 could be used on my 2390 but then got told later when queried couldn't get it working that audio must be in wav format |
Posted: Sun Oct 07, 2012 7:10 pm Post subject: |
the unit is a 2545 lm and it dose support mps anyway got it working with the wav files thanks for all your help one more thing can you get custom voices for garmin ? |
Posted: Wed Oct 10, 2012 8:24 pm Post subject: |
RODTROTTER wrote: | the unit is a 2545 lm and it dose support mps anyway got it working with the wav files thanks for all your help one more thing can you get custom voices for garmin ? |
according to their product specifications it does not support mp3
