Pocket GPS World :: View topic - TomTom battery help
TomTom battery help
andythewelder
PostPosted: Thu Nov 18, 2010 6:53 pm    Post subject: TomTom battery help Reply with quote
hello all, new to the forum and seeking some advice about my tom tom.
I have a tomtom one it says its 4n00.012.
The problem is that my wife tried to plug it in and has damaged the pins and block for charging, as this tomtom has been reliable to me and i rely on this to work over the next couple of days i don’t have time to get it repaired. i am wondering if i could do a slight modification without damaging it. Here goes this was my plan - because the unit does not charge from the connector i opened it up and wanted to see how easy it would be to resolder a new block on, i am not good with a soldering iron and have asked other shops with replies that's going to out cost what the thing is worth.
My plan is to remove the battery and cut the 3 wires that go from the board to the battery and simply bring in the 2 wire's from my 5v car charger through the case and connect them 2 the other wires bypassing the battery.
I see an advantage to this is i am not relying on a battery for the unit to power up it's hardwired to the charger.....Would this work
The battery is a Maxell battery with 3 wires red, yellow and black. from the charger i have a black and a red, would it be as simple as joining these and able to power the unit up. I know it sounds kind of dodgy, but i would fully protect each wire from touching etc.
Any help would be great thanks.
PaulB2005
PostPosted: Thu Nov 18, 2010 7:10 pm    Post subject: Reply with quote
Subject edited to something more meaningful
PostPosted: Thu Nov 18, 2010 7:51 pm    Post subject: Reply with quote
Have a closer look at the battery and you will see its rated at 3,7 Volts, if you cut the wires and feed 5 Volts directly to the PCB you will let all the smoke out and the device will fail to work ever again.
If you can rig up a 3,7 volt feed in to the unit then the idea has some merit but you need to be very careful with voltage regulation otherwise the smoke will escape with the same resulting damage.
Go and purchase a new unit as its going to cost more to repair to be honest - Mike
PostPosted: Thu Nov 18, 2010 8:07 pm    Post subject: Reply with quote
Is the power input socket the old style DC Jack or the newer USB connector?
Where are you based? It would be better to try to find a repairer with a better pricing structure (I might offer to try myself)
andythewelder
PostPosted: Thu Nov 18, 2010 8:49 pm    Post subject: Reply with quote
thanks for the replies, i have the original old style charger, its 12v in and says output :5v 2A
im in ayrshire scotland, nobody round here that can fix it. been a reliable unit and would hate to get rid of it. so close to christmas the wife would kill me if i wanted a new one Sad
andythewelder
PostPosted: Thu Nov 18, 2010 8:53 pm    Post subject: Reply with quote
if i could get a new charging block soldered on then great, but would possibly cost more than its worth. the black plastic bit on the inside of the block (with the pins) is not secured, the little holder at the back of the block connector has snapped meaning the pins dont line up with the board.
Anita
PostPosted: Thu Nov 18, 2010 9:19 pm    Post subject: Re: TomTom battery help Reply with quote
Confused
Anita
TomTom VIA 135 - App 12.075
UK map 1125.12264
Samsung Galaxy S21
22.034 (27 Mar 24)
