Pocket GPS World :: View topic - poiedit v3.2 & xml error
bluejets
PostPosted: Sat May 29, 2004 5:46 pm    Post subject: poiedit v3.2 & xml error Reply with quote
Hi. Could I get some help getting POIEDIT 3.2 to work. This is the first time I have tried to install and use this program. After installing I get "could not download version information because of the following exception". "Invalid xml, no document element found" <?xml version="1" encoding="UTF-8">.<version><Current><3.2.0.73</Current>. </Version>. Also simply get invalid xml error when I try to connect again. What I am I doing wrong? I have windows XP SP1 with IE6.
thanks for any advice in advance.
selwonk
PostPosted: Fri Nov 11, 2005 2:05 pm    Post subject: Re: poiedit v3.2 & xml error Reply with quote
Which site is giving you the error? I've got the same problem with PoiHandler in my list, which happens to be first in the list. I know the XML is correct, cos I've tested it...
selwonk
PostPosted: Fri Nov 11, 2005 4:44 pm    Post subject: Reply with quote
Ok - easy fix actually. Go to the PoiEdit directory (usually C:\Program Files\Dnote Software\Poi Edit) and delete the .inf and .xml files for the entries in your site name list. Once you click on them again, it will download a fixed version...
MK
Mike Knowles
22.043 (17 Apr 24)
