dhn Frequent Visitor
Joined: Oct 08, 2007 Posts: 2544 Location: Toronto CANADA
Posted: Thu Mar 18, 2010 12:12 pm Post subject: |
Darren wrote: | I can't see any map version info on the Routes web-site so I'd be wary of assuming it uses the latest data? |
I have been told (for NA, anyway) that route planner is one version behind actual. If that is the case, I presume it's at 840 for NA now. _________________ David |
joaocb40 Occasional Visitor
Posted: Fri Mar 19, 2010 10:01 am Post subject: |
No, it is not the latest map. |
Andy_P Pocket GPS Moderator
Posted: Fri Mar 19, 2010 8:05 pm Post subject: |
AFAIK, the Routes web-site is currently on v840 for the UK and Europe too. |
falkirk81 Pocket GPS Verifier
Joined: Jul 07, 2006 Posts: 1649 Location: Newcastle, England, UK
Posted: Fri Mar 19, 2010 8:39 pm Post subject: |
Andy_P wrote: | AFAIK, the Routes web-site is currently on v840 for the UK and Europe too. |
Andy is correct. All you need to do is look at the Northbound carriageway of the Forth Road bridge in Edinburgh. It should NOT be a toll road, and up till and including v8.40 maps, it has been marked as a toll road.
v8.45 map data now has this correct.
So when you see the toll charge part of that bridge removed, then it will be the latest map data
Same principal applies to the Tay bridge in Dundee, the SB carriageway should NOT be a toll road. v8.45 map data has this correct too!
Steven _________________ Tomtom GO 1005 LIVE
iPhone 12 |
DennisN Tired Old Man
Posted: Fri Mar 19, 2010 8:46 pm Post subject: |
Shows what a gullible old man I am - if TomTom offer me something, I'll believe it.  _________________ Dennis
Two of them are obesiting!! |
tonygold Frequent Visitor
Posted: Thu Mar 25, 2010 9:32 am Post subject: |
mikealder wrote: | jimbo_hippo wrote: | My postcodes are missing. Not so much a map update issue, it was left from a recent wipe but after 6 years of Brits complaining about this it's still not fixed. |
If you click Here you will download the latest PostCode data for your device, just unzip the download to the device - Mike |
hi
what folder do you paste this info into please, is it the same folder as the pgpsw speed cams are in? also would this info be more up to date than the info on my 1 year old tomtom one IQ routes has built in? and if so will it simply overwrite the older data.
many thanks. |
Robin2 Lifetime Member
Posted: Thu Mar 25, 2010 9:49 am Post subject: |
No, you don't go into the map folder. In the root of your device you should see a folder called Zip. This should contain 4 files, 2 for UK and 2 for Netherlands. You just unzip the new postcode files into this folder - it should overwrite the old ones (you will be asked first). Don't forget to back up the old Zip folder onto your desktop first, in case the new one is corrupted for some reason
Robin _________________ TomTom One v3 Europe, Navcore 7.903, Western Europe 835.2420
Satmap Active 10
Plus a lot of other PDA GPS kit, seldom used |
Posted: Thu Mar 25, 2010 9:57 am Post subject: |
Robin2 wrote: | No, you don't go into the map folder. In the root of your device you should see a folder called Zip. This should contain 4 files, 2 for UK and 2 for Netherlands. You just unzip the new postcode files into this folder - it should overwrite the old ones (you will be asked first). Don't forget to back up the old Zip folder onto your desktop first, in case the new one is corrupted for some reason
Robin |
thanks robin.
i will do that now. would this new zip file be more up to date than a year old one in your ooinion? |
Posted: Thu Mar 25, 2010 11:43 am Post subject: |
It's the very latest, 845. I just checked my own device, which I updated fairly recently, and that's 801, so I'm going to update mine, too
Satmap Active 10
Posted: Thu Mar 25, 2010 8:45 pm Post subject: |
In the zip folder, double click the Great_BritainPostal.ver and open it with Notepad - it'll say the version number. _________________ Dennis
Posted: Fri Mar 26, 2010 8:08 am Post subject: |
DennisN wrote: | In the zip folder, double click the Great_BritainPostal.ver and open it with Notepad - it'll say the version number. |
thanks for info dennis |
