Pocket GPS World :: View topic - Used SD Map Cards
Used SD Map Cards
MickeyM
PostPosted: Sat Oct 03, 2009 10:30 pm    Post subject: Used SD Map Cards Reply with quote
Is it possible to get a used SD Map card to work in my Tomtom 720. Thanks.
EricWB
PostPosted: Sun Oct 04, 2009 10:02 am    Post subject: Reply with quote
Others will be able to give you a more precise answer but in general its no you cannot use any map unless it was purchased and first registered by encoding it to your device.
If it were possible TT would not be able to make much money from supplying replacement maps as they would all be rapidly cloned. Some may think that's a good thing, but all it would mean is actual purchasers of the genuine item would end up having to pay double or treble the existing prices.
PostPosted: Sun Oct 04, 2009 2:00 pm    Post subject: Re: Used SD Map Cards Reply with quote
If it is an old map and you have the "Product code" for it then yes...
SEE HERE
MickeyM
PostPosted: Sun Oct 04, 2009 6:59 pm    Post subject: Reply with quote
Many thanks for that.
22.044 (24 Apr 24)
