Pocket GPS World :: View topic - Origin's B2 laser detector with a 2.5mm jack - PDA?
mixer25
PostPosted: Sat Mar 27, 2004 7:54 pm    Post subject: Origin's B2 laser detector with a 2.5mm jack - PDA? Reply with quote
Can the laser detector on a B2 be used in someway with a PDA?
as I got a spare one and wanted to rig it up to my PDA.
PostPosted: Sat Mar 27, 2004 8:04 pm    Post subject: Reply with quote
No
mixer25
PostPosted: Sat Mar 27, 2004 11:53 pm    Post subject: Maplin Reply with quote
mmm, how can you be so sure?
I am sure something could be done with one and a maplin store Happy
PostPosted: Sun Mar 28, 2004 9:08 am    Post subject: Reply with quote
You're missing all the electronics necessary to decode the signal and produce an alert. All the Laser Module does is pass a signal when it is triggered, you then need top process the signal, filter out false alarms and responses outside the range you expect laser speed guns to use and produce an output that can be read on the pocketpc.
Sure if you are experienced with the programming of custom PIC microprocessors and .Net for the PocketPC anything can be done but I think this is outside the scope of most users and as I have explained pointless anyway as the Laser detetction feature is next to useless anyway!
22.043 (17 Apr 24)
