Pocket GPS World :: View topic - Garmin Colorado and Mapsource
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Garmin Handheld GPS Receivers
docdyson
PostPosted: Sun Apr 27, 2008 9:10 pm    Post subject: Garmin Colorado and Mapsource Reply with quote
I have a problem using Mapsource. If I make a route and download it to my Colorado all the waypoints etc work fine, but the route simply becomes a series of straight lines between waypoints. If I make a route on the Colorado and reverse the process, the route appears as a series of straight lines on the PC. Curiously this happens when the routing is set to automotive or to cycling on roads.
Any ideas? Sad
missing_user
PostPosted: Sun Apr 27, 2008 9:20 pm    Post subject: Reply with quote
What mapping software?
Is the mapping software unlocked?
Did you transfer data for autorouting?
Is the Unit set for pedestrian?
Am I a pain asking all the questions???? Very Happy
docdyson
PostPosted: Sun Apr 27, 2008 10:46 pm    Post subject: Reply with quote
Not a pain at all! I'm only too grateful.
1. Mapping software Mapsource/City Navigator 2008 NT (although the same prob arises with my Mac and the equivalent called "Bobcat").
2 Fully unlocked putting the map onto an SD card works fine
3. Unit set for automobile in this case but the same thing happens in cycling (set for the road).
Andy
missing_user
PostPosted: Mon Apr 28, 2008 12:13 am    Post subject: Reply with quote
On mapsource on the PC - as you select the maptiles - bottom left of screen - there should be this option:-
Include route calculation data
did you select it?
docdyson
PostPosted: Mon Apr 28, 2008 6:57 am    Post subject: Routing problem Reply with quote
No! I'll check it out tonight.
Andy
docdyson
PostPosted: Mon May 05, 2008 9:51 pm    Post subject: Colorado 300 failure! Reply with quote
Hi Sorry for the delay. I have been busy this week. Anyway my Colorado 330 won't boot anymore, nor will it hard reset. Tried all the tricks on the Garmin Colorado Wiki but the computer no longer recognises it as a USB device!. I'll be phoning Garmin in the morning.......
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Garmin Handheld GPS Receivers All times are GMT + 1 Hour
22.043 (17 Apr 24)
