GPS_fan Pocket GPS Moderator
Joined: Jan 04, 2007 Posts: 2789 Location: Hampshire, UK
Posted: Wed Mar 19, 2008 9:53 am Post subject: Mio C620(t) battery life |
From a full charge to the device being completely discharged and turning itself off, I'm only getting a maximum of 90 minutes use from the built-in battery.
Is this normal for this device, or could the battery be faulty?
I've been to the Support pages and found an article about battery memory effects - which is says don't affect the C620, but it does say that the circuitry may get confused and gives instructions to overcome this. I followed these instructions, completely discharging and then fully charging the battery, but this has made no difference _________________ Andy
PocketGPSWorld.com supports Help for Heroes - Read here |
chris_ah1 Regular Visitor
Posted: Wed Mar 19, 2008 3:52 pm Post subject: |
sounds about on par for these devices now. the 5 to 8 hours being quoted on spec pages is lunacy.
You can always disable stuff like the bluetooth for instnace, use hedphones instead of a speaker, dim the screen until it is almost black etc.....to get the time. |
Posted: Wed Mar 19, 2008 9:54 pm Post subject: |
I hadn't thought of turning bluetooth off, but backlight has already been turned down to about 60-70% _________________ Andy
Posted: Wed Mar 19, 2008 11:50 pm Post subject: |
I know there are meant to be standards for battery life testing, but I've personally seen some companies demo a display tech with it set to the lowest display brightness - e.g. with a macbook pro the chap was demoing. He needed the backlight at 10% during a demo to prove the battery life was within limits of the quoted times whilst looping a simple web browsing benchmark....from the HD :S.
Only way to get 6hours is to turn off gps antenna, turn off bluetooth, sound, backlight, bells and whistles etc :p
gl. |
