Newsletter
Pocket GPS World :: View topic - Mio 168 CLONE (NO BLUE SATS SHOWING)
Goto page 1, 2, 3  Next
berghaus
PostPosted: Sat Jan 14, 2006 1:59 am    Post subject: Mio 168 CLONE (NO BLUE SATS SHOWING) Reply with quote
I have a clone Mio 168 with Medion, I have installed TTN5 and all is fine but the sat bars won't go blue or show sats on navigation page, does any one know how to fix this.
Any help would be great.
Thanks Rob
MIO 168 + MICROMAXX MDPPC 150 WITH MEDION FIRMWARE UPGRADE (A MUST FOR TTN5)
TTN5
Memory Map 2004 1:50000 & 1:25000 + AERIAL ALL UK (FANTASTIC)
Mountain Biking (OFF ROAD)
Hiking
Pocketgps
PostPosted: Sat Jan 14, 2006 3:59 am    Post subject: Reply with quote
I have a Medion GPS Firmware update that will solve that problem
Download Here
Follow the ReadMe.txt file that's in the file.[/quote]
dabut
PostPosted: Sat Jan 14, 2006 10:14 am    Post subject: Reply with quote
i have already done that upgrade and it works great
Skull66
PostPosted: Sat Jan 14, 2006 12:21 pm    Post subject: Reply with quote
Does this update work with the md95459 with 2.4.13.03.10 firmware?
Pocketgps
PostPosted: Sat Jan 14, 2006 9:18 pm    Post subject: Reply with quote
The update was made for the Medion MD95000 - Model No. MDPPC150.
I WOULD NOT TRY IT, IT MAY PERMANENTLY RUIN YOUR UNIT AS THERE WOULD BE NO RETURN IF IT FROZE
Skull66
PostPosted: Sat Jan 14, 2006 11:33 pm    Post subject: Reply with quote
trouble is the md 95459 is also model mdppc150, thats why I asked
berghaus
PostPosted: Sun Jan 15, 2006 1:31 pm    Post subject: Reply with quote
Download Here
[/quote]
Hi and thanks for your reply.
I think I need to be more accurate with what I have and what I want to do.
I have a Micromaxx (Mio 168 Clone) with Navteq on board, the software that comes with it is Medion Navigator 5.
What I have done is removed the Medion software from the SD card and also from the PDA, leaving me with just the Sat. symbol in the bottom right of screen.
I have installed TTN5 and all is OK appart from I can't see how many Sats. there are in the Sat bar and on the Sats page they stay grey and don't turn to blue, also it seems to take longer than my old origonal Mio 168 to get a Sat. lock.
Is it ok to use the firmware update that you quote above to solve my problems with the system I have quoted above.
Thanks for your help
Rob
TTN5
Hiking
berghaus
PostPosted: Sun Jan 15, 2006 3:24 pm    Post subject: Reply with quote
berghaus wrote:
Download Here
Rob[/quote]
WOW tried it, Works 100 percent PERFECT.
If you have just bought the Micromaxx (MDPPC 150) Medion, and you want TTN5 on this is a must, and it gets rid of the Medion GPS symbol in the bottom right of PDA screen, you get instant Sat. fix, and they turn blue.
Thanks GPS Team
Rob
TTN5
Hiking
Pocketgps
PostPosted: Sun Jan 15, 2006 3:38 pm    Post subject: Reply with quote
The firmware update was made some 12 months ago for the Medion 95000, so I just don't know if it would work for these later models.
I must admit that when I put TT5 onto the Medion I had the same thing as you have, TT5 took about 3-5 mins to get a lock at the best of times and the bars on the sat page did not turn blue, but it had a lock because the map turned from grey to the normal colours and I could navigate ok.
With the updated firmware the bars did show blue but I don't think that I get a lock much quicker.
If I start (cold start) the Medion 95000 & the Mio168 at the same time now, the Mio168 usually gets a lock about 45 seconds quicker than the Medion.
Because firmware updates can make a system useless I WOULD NOT RECOMMEND DOING IT.
Even on the Mio168 TT5 is a lot slower to lock on than TT3, and this I have seen in the forums here with several makes of PDA's/GPS units, so it's not just the Medion combination.
Sorry to sound so negative, but better to have a slow lock than no lock at all with a useless system.
Pocketgps
PostPosted: Sun Jan 15, 2006 3:49 pm    Post subject: Re: Mio 168 CLONE (NO BLUE SATS SHOWING) Reply with quote
I missed this last part of your post.
TO ANY BODY USING THIS UPDATE - DO IT AT YOUR OWN RISK.
UEF
PostPosted: Sun Jan 15, 2006 8:16 pm    Post subject: Reply with quote
I'm another Medion/168/Micromaxx/PPC150/Partridge in a Pear Tree user and I confirm you get much better GPS reception here, and yes a nifty sattlite display. I still have the GPS icon in the system try, but its "off" and only comes on when tomtom accesses it. Ditch the medion stuff too ;)
xnaught
PostPosted: Sun Jan 22, 2006 11:29 pm    Post subject: Reply with quote
Hi guys.
Anyone know if this works with a PNA175?
Got the same problem and want the bars to be there Sad
UEF
PostPosted: Mon Jan 23, 2006 12:30 am    Post subject: Reply with quote
Have their been any newer firmwares released since?
illusion786
PostPosted: Mon Jan 23, 2006 12:50 am    Post subject: Reply with quote
i got mine to work with the FW update.
Thank you Pocketgps
I have the Micromaxx MDPPC150 MM95563
And is working perfectly with the update. The bars are working.
Skull66
PostPosted: Mon Jan 23, 2006 4:09 am    Post subject: Reply with quote
took the risk, and it worked for me too :D
Page 1 of 3
20-071 (06 Jul 22)
Terms & Privacy
