Pocket GPS World :: View topic - Edge 305
Edge 305
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Cycling, Sports and Fitness
marinrider2007
PostPosted: Sun Jul 01, 2007 6:04 pm    Post subject: Edge 305 Reply with quote
Hi guys
Thinking of getting one of these.
Does anyone know if the newer range of polar 'wear link' chest straps are compatible with the 305?
Also is it possible to use memory map on the 305 or is it simply possible to download wayoints etc as I would with my currect gps unit 'garmin vista'?
Are there kits to allow fitting the main unit to several bikes?
Thanks fo taking the time to read this ad replying if you did.
PostPosted: Wed Jul 18, 2007 10:14 pm    Post subject: Reply with quote
I believe that the heart rate monitors are specific to the Garmin range (but I may be wrong). I have a Polar HRM which is not compatible, but I am not sure which one it is.
You can use Memory Map, but you cannot download the maps to the Garmin. The Memory-Map application is aware of Speed, Elevation, and Heart Rate profiles, and can of course exchange waypoints and routes. You need to be aware of the limited amount of memory in the 305.
I am sure that Garmin will be able to supply spare mounting kits. If memory serves correctly there were two supplied with the package.
Post new topic   Reply to topic    Pocket GPS World Forum Index -> Cycling, Sports and Fitness All times are GMT + 1 Hour
22.043 (17 Apr 24)
