Pocket GPS World :: View topic - i3 Battery Options
i3 Battery Options
robbooth
PostPosted: Thu Aug 31, 2006 9:07 am    Post subject: i3 Battery Options Reply with quote
If the i3 doesn't charge from the in car power lead, what difference does the battery option (alkaline or NiMh) in the setup menu do?
Ash10
PostPosted: Thu Aug 31, 2006 9:26 am    Post subject: Re: i3 Battery Options Reply with quote
Alkaline and NiMh batteries have slightly different voltages and discharge characteristics.
It doesn't really matter which option you have it set to - it's just there to try and make the battery level indicator more accurate.
Mr_Gonzales
PostPosted: Thu Aug 31, 2006 1:57 pm    Post subject: Reply with quote
But regardless of what option you select, most i3s will get down to two bars (out of the four possible), flash up the low battery warning and turn off ten minutes later. Accuracy is not a strong point on that battery guage.
Ash10
PostPosted: Thu Aug 31, 2006 2:08 pm    Post subject: Reply with quote
I did say that it was there to try to improve accuracy - I didn't say that it actually worked Laughing Rolling Eyes
zogman
PostPosted: Thu Aug 31, 2006 2:18 pm    Post subject: Reply with quote
you'll also find that when running on batteries , (and the batteries are low) any voice navigation will shut done the unit due to the power drain...
pgatens
PostPosted: Mon Sep 04, 2006 4:56 pm    Post subject: Reply with quote
I find that my i3 (fitted to my triumph Tiger motorcycle with power lead) goes mad when the internal batteries levels fall. First i get a bleeping noises and then it tries to turn itself off and then comes back on again
paul
hertford
22.043 (17 Apr 24)
