Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10641 Location: Suffolk, UK
Posted: Sun Aug 13, 2006 8:23 am Post subject: |
MickeyM wrote: | and made the previous one data.chk old, but I am not getting voices | Rename the old File as old.data.chk
MickeyM wrote: | by the way I dragged and dropped into place, did not go through Tomtom home as did not know how with data.chk. Mike | The best way as HOME only seems to handle TT downloads.;) _________________ Richard
TuurG Frequent Visitor
Joined: Nov 23, 2004 Posts: 454 Location: Haarlem, The Netherlands
Posted: Sun Aug 13, 2006 11:28 am Post subject: |
Oldboy wrote: | The best way as HOME only seems to handle TT downloads.;) |
If you put the new data.chk file in your HOME download folder, and place a .toc file next to it, describing the file, then HOME will be able to install it.
I tried to put example content for such a .toc file here, but it does not allow me. Error that I use not allowed HTML tags. _________________ GO1005
MGC GT 1968
MGB Cabrio 1973 |
MickeyM Lifetime Member
Joined: May 12, 2005 Posts: 216 Location: Norfolk UK.
Posted: Sun Aug 13, 2006 12:52 pm Post subject: |
Richard, what data.chk did you use on your Classic with version 6.150. 7120 does not work for me. Regards Mike. |
Posted: Sun Aug 13, 2006 2:19 pm Post subject: |
MickeyM wrote: | Richard, what data.chk did you use on your Classic with version 6.150. 7120 does not work for me. Regards Mike. | I haven't tried the data.chk yet as I don't use it very much anyway. Will give it a GO sometime.;)
Did you rename the old data.chk File as I suggested? Did it make any difference? _________________ Richard
Posted: Sun Aug 13, 2006 3:32 pm Post subject: |
Yes I did and it did no good, Many thanks, Mike. |
Posted: Sun Aug 13, 2006 4:01 pm Post subject: FOR LUTZ |
Hi Lutz, Are you able to give me voices for Gatso/Temp/Redlight/Specs/Mobile. I am running Tomtom Go (Classic) and have just upgraded to firmware 6.150. Having tried the 7120 download to no avail don`t know what else to do.
Divice AK*** AJ*** Edited out by Oldboy.
App:6.150 (7120/060801)
GPS Ver: V1.21 Boot 4.29
Map: Great_ Britain_Plus Map Ver: V571.0
Many thanks, mike@marsh500.wanadoo.co.uk |
Posted: Sun Aug 13, 2006 8:46 pm Post subject: |
Thanks Oldboy. Mike |
Posted: Sun Aug 13, 2006 9:09 pm Post subject: |
Voices are now working with 6.150/7120. I had put the data.chk in Map of Great Britain folder. Thanks for all your help,Mike. |
Posted: Sun Aug 13, 2006 10:15 pm Post subject: |
Richard, Could you tell me if there should be any data.chk within the map of Great_Britain_Plus Map as I deleted 7120 from there and put it into the main directory and got camera voices back, but I still have a data.chk old, in the map folder, I think I must have put it there when updating before and wonder if I should delete it as I did with the 7120. Regards Mike. |
Posted: Mon Aug 14, 2006 7:10 am Post subject: |
MickeyM wrote: | Could you tell me if there should be any data.chk within the map of Great_Britain_Plus Map | All data.chk Files should be in the Root of the SD Card. I would leave the old one in the Map Folder as it can then be your Backup, if ever needed.;) _________________ Richard
Posted: Mon Aug 14, 2006 10:31 am Post subject: |
Many thanks Richard, Com-on Ipswich. |
rb5286 Occasional Visitor
Posted: Mon Aug 14, 2006 11:08 am Post subject: |
just to clarify.
my TTG 700 is running latest version 6150 and i have just installed the data.chk file 7120
as per my previous post, I have found that if I dont click on the icon in the system tray (bottom right of taskbar) to 'safely remove hardware' and just unplug lead TTG reboots ok.
As for the 7120 data.chk file this isnt working have put the file in both western europe folder and root folder. |
Posted: Mon Aug 14, 2006 11:19 am Post subject: |
have just noticed that when connecting to the TTG via TT Home I have noticed the following:
the version shown is 6.100 compared to 6.150 when shown on the TTG screen when not connected
the 7120 camera warning sounds are ok when accessed directly on the TTG but when accessed via TTH the sounds are the original ones
anyone got any ideas on these weird happenings??? |
BlankSheep Occasional Visitor
Posted: Wed Aug 16, 2006 2:18 pm Post subject: |
Hi, thought I'd share my experiences of upgrading TTOne from 5.4x to 6.15.
TT Home installed under XP on my PC, then I downloaded the 6.15 update and transferred it to my TTOne. All seemed fine until after a couple of power off/on cycles it stopped talking to the PC via USB. The PC would not see the TTOne and the TTOne went straight into navigate mode.
The only way I could get the USB functionality back was by a "paperclip reset" and this only lasted for a couple of power on/offs before losing USB yet again.
Finally I did a "Factory Reset" from the TTOne menu, went through basic setup, powered down, did a "paperclip reset", powered up and re-entered my favourite setting etc. Now the TTOne asks (on its display) if I want to connect to the computer whenever it detects the USB is connected - I guess this is new functionality which had been "suppressed" by the old configuration. Its been fine since. Bit of a pain losing the favourites and personal defaults but at least its working properly now.
So maybe some older configuration settings are incompatible with the new software. The only way to find out may be to do a factory reset - take plenty of backups along the way too - just in case!
Hope this helps someone.
Can anyone point me to an overview of the TT file structure - what files do what etc? Just curious.
BS |
Posted: Fri Aug 18, 2006 6:59 pm Post subject: |
i got a reply from TT
Quote: | Thank you for contacting TomTom Customer Support.
Please do the following:
Reset the device using a paper clip, but do not turn it on.
Connect the device to your PC using the USB cable.
Turn on the device with pressing the on/off button for 3 secs.
Go to "My Computer" and browse the 700's Hard disc.
Delete all files in the root directory of the hard drive except for the folders.
Start up TomTom HOME and re-install the application only from the middle section.
With best regards,
The TomTom Customer Support Team |
Has any1 else notcied that you cant send or receive text messages to TTG on this 6.150 update? |
