Pocket GPS World :: View topic - audio
audio
xp
PostPosted: Tue May 16, 2006 12:57 am    Post subject: audio Reply with quote
Do you know if the tomtom 910 has a audio out put for a extension speaker. Sad
Les
PostPosted: Tue May 16, 2006 4:18 am    Post subject: Reply with quote
No it does not, the audio output is intended to go into the Stereo for amplification before playing through the speakers, the inbuilt speaker is actually very good itself, but limitted to mono - I always go with the external feed into the cars Kenwood system - Mike
PostPosted: Tue May 16, 2006 11:34 am    Post subject: Reply with quote
Or you can buy an amplified external speaker
xp
PostPosted: Tue May 16, 2006 7:04 pm    Post subject: External speaker Reply with quote
Hi Andy
Where world you plug the external speaker in to if there is no speaker out put.
Les
PostPosted: Tue May 16, 2006 7:11 pm    Post subject: Reply with quote
An amplified speaker (the same type you have on your PC) will connect to the Go-910 car mount and it will then work just fine, its a shame the home mount is missing this feature, as I feel it would be worth while - still you can't have everything - Mike
xp
PostPosted: Tue May 16, 2006 7:17 pm    Post subject: Speaker Reply with quote
Thanks for all the info mike
Les
PostPosted: Wed May 17, 2006 12:07 am    Post subject: Reply with quote
xp-
The Go910 does not have a "speaker" output i.e. an output with enough power to drive a loudspeaker.
It does have a "line" output, i.e. an output similar to the phono outputs on a C.D. player, which is suitable to feed power amplifier which in turn feeds a loudspeaker.
A "powered (or amplified) loudspeaker" is simply a power amplifier and a loudspeaker in the same box. Examples are the speakers attached to most PCs, or the little speaker systems sold for Walkmans and iPods. One of these, either battery powered or capable of being run from the 12 Volt car supply,, would work fine with the Go910.
Gerco
PostPosted: Fri May 19, 2006 8:03 pm    Post subject: Reply with quote
Check here
[http://www.fastmute.de/vers02_engl/index2.php?id=&parent=&versendet=]
Much better with more power and more features.
Designed for any car radio.
You get your voice commands highly amplified (10 W) out of your car speakers.
Ultra fast switching mute generator.
Gerco
JockTamsonsBairn
PostPosted: Sat May 20, 2006 1:20 am    Post subject: Reply with quote
Gerco wrote:
Check here
Gerco
Code:
[url=http://www.fastmute.de/vers02_engl/index2.php?id=&parent=&versendet=]here[/url]
here
Jock
PostPosted: Sun May 21, 2006 6:21 pm    Post subject: Reply with quote
Why is the additional device required? If you load the mp3 to the GO-910 it will automatically perform the function of switching between music, navigation and alert warnings. All you need to make sure is you can get the audio output from the Go device into the car system. Mike
