Pocket GPS World :: View topic - First sync issues
First sync issues
Goto page Previous  1, 2
nicknick
PostPosted: Sun Sep 14, 2003 8:04 am    Post subject: First sync issues Reply with quote
Hmm,
I have no probs with you getting a little chef bitmap from elsewhere, but I did include it in the original zip file I sent you.
I had a couple of personal queries regarding it and I thought you had omitted it for 'Copyright' issues
I expect RobMob's will be just as good
Nick
Yep, I've been finding issues with the POI's we have on the POI page. Mainly because a lot have spaces in them, and fail to download correctly with POI-Edit. I've changed these in the sync, and there are also some where I've tried to make it a little bit more descriptive, so there will be some although identical in the Sync Service and the POI page, they may have slightly different names. I've thought about renaming these on the POI page, but this may confuse anyone who's downloaded them in the past.
Thanks for the Little Chef bitmap, I'll add that in shortly.
RobMob
Only problem I had is that I had downloaded the McDonalds POI about an hour earlier for the POI listsings prior to downloading POIEdit. When I checked TT for the POIs that were available i had two versions - one (first download) called McDonalds and the second (POIEdit download) called McDonalds_Midlands. I hadn't changed the name of either - was there a name change for this file at PocketGPS in the hour or so between download of two files? (18:46 to 20:56). Same also occurred for Little Chef but I first loaded that back in April.
Dave - have emailed a Little Chef bitmap to you.
RobMob
timtim
Everything OK now, thanks.
Re. the graphics: Rasoft do a neat little package for editing bitmaps & jpegs on your handheld, have a look if you haven't seen it.
It seems I don't know anything after all
Thanks guys, looks like there was a problem when I switched to another FTP client last night, no BMP's went over in the batch update.
Problems with the following BMP's have now been fixed:-
  • Airports_UK
  • Esso_Petrol_Stations
  • KFC
  • Marriott
  • Pizzahut
  • Shell_Petrol_Stations
  • Texaco_Petrol_Stations
  • Total_Petrol_Stations
I also noticed the McDonalds_Midlands OV2 and BMP were missing, and these have been added.
I do agree with a graphics design, if anyone wants to do any, I can upload them. Some of the logos are pretty poor.
Tim, are you running through a proxy server ? Can you open POI-Edit and then select FILE | OPEN REMOTE and after about 30 seconds you should get a window to your Pocket PC ? If you get this okay, then the connection between POI-Edit and the Pocket PC is okay, but it's probably you're internet settings. Perhaps you're using a proxy server that's blocking access ?
timtim
I get the same error message as above but without being able to download anything. I've unchecked the 'Auto configure' box in the internet settings, but still getting nowhere. Any advice?
fysmd
On my 1st sync I got the same error but for Esso, then on the next sync for KFC, next sync Marriott...
Each time I get further through the sync and there are POI files appearing in my map directory, just some BMPs missing.
Looking good...
View user's profile Send private message Send e-mail AIM Address Yahoo Messenger MSN Messenger
Page 2 of 2
21.034 (22 Mar 23)
