longwori Regular Visitor
Joined: 15/04/2003 12:14:36 Posts: 151 Location: Cheshire, UK
Posted: Sat Aug 13, 2005 1:58 pm Post subject: Re: HP2210+TT5+CP5 |
Trev7186 wrote: | Currently i have the latest upgrade of TT5 (5.201) but ive taken off CP, Ive got the latest upgrade for that too (5.02). Any more hints or tips on this would be greatly appreciated. |
Trev the 5.201 upgrade is fo the tomtom go unit, not your PDA. If you have really managed to install this, it could be causing you problems. The latest tomtom version for a PDA is 5.1 - Have another look on the tomtom support page, you have to scroll quite far down for the Tomtom Navigator 5 update.
Good luck,
Ian _________________ TomTom Go 520, HTC Wildfire with CoPilot Live Premium UK & CoPilot Live Standard USA |
Trev7186 Occasional Visitor
Joined: Aug 12, 2005 Posts: 15 Location: Lutterworth, Leicestershire
Posted: Sat Aug 13, 2005 4:35 pm Post subject: TT5+CP5 |
Hi Brob, did you uninstall CP then manually remove all the folders that where left, then reinstall the latest version of CP? thats what i did.
Trev |
Posted: Sat Aug 13, 2005 4:42 pm Post subject: Sorry about double posting |
couldnt find an edit? Yep ive got the CP Version 5.02 it says its for pocket PC? here the link http://www.oabsoftware.nl/count.php?fil=http://checkpoint.oabsoftware.nl/images/SetupCheckPOInt5.exe&ver=5.0.2 seems to be working fine road tested it this morning no probs (mind you it was only a short trip) had to turn of the visual display of the count down to camera bar though as it was flashing and distracting me. I'm sure with our joint efforts we will get to the bottom of this :D .
Trev |
Pocketgps Lifetime Member
Joined: Nov 16, 2004 Posts: 2145 Location: Midlands, UK
Posted: Sat Aug 13, 2005 5:59 pm Post subject: |
Finally got CheckPOInt to work OK, but only after several tries, now many of you may not do this but I always do a FULL Backup after installing anything to my PDA when I know it works fine, so as I have only 6 things loaded then after each one is loaded I back it up, so that at any stage I can restore it to whatever stage, so I Hard reset my PDA and loaded from the backup all the programs before I ever put TT 5 on it, loaded TT 5 then soft reset, loaded TT 5 update then another soft reset, then loaded CheckPOInt 5.02 and another soft reset and bingo, it works OK from either starting from CheckPOInt or from within TT 5, in fact don't seem to be able to get it to go wrong at all now, have been out on the road, navigated to a couple of local places and also just used a map and all worked fine.
Will let you know if anything else transpires. |
Posted: Sat Aug 13, 2005 8:24 pm Post subject: TT5+CP5 |
Hello again,
Anyone know what files or folders contain my favourites and POI's in case i ever need to do a complete reinstall of TT5?
Thanks in advance
Trev |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10641 Location: Suffolk, UK
Posted: Sat Aug 13, 2005 11:26 pm Post subject: Re: TT5+CP5 |
Trev7186 wrote: | Hello again,
Thanks in advance
Trev |
It's the .cfg file in the Map Folder. Usually called Great_Britain-Map.cfg or similar.
Your custom POI's will be in the same Folder and consist of a .ov2 file with a matching .bmp. _________________ Richard
brob108 Occasional Visitor
Posted: Sun Aug 14, 2005 3:35 am Post subject: Re: TT5+CP5 |
Trev7186 wrote: | Hi Brob, did you uninstall CP then manually remove all the folders that where left, then reinstall the latest version of CP? thats what i did.
Trev |
Hi Trev
Which files and folders should I manually delete once I have removed the Checkpoint program? |
Posted: Sun Aug 14, 2005 8:47 pm Post subject: TT5+CP5 |
Hi Brob,
you delete anything with reference to CP, i'm not sure if it made any difference but its worth a go.
Trev |
Posted: Mon Aug 15, 2005 12:07 am Post subject: |
Hi Trev
Deleted everything Checkpoint related and still no joy alas! What system are you using TTN5 and Checkpoint on? I'm wondering if it may be a Windows Mobile 2003 Second Edition/IPAQ HX 2750 issue?
Regs
Brian |
Posted: Mon Aug 15, 2005 4:37 am Post subject: |
Hi Brob,
I'm using a HP2210, Windows CE 4.20 and a sysonchip CF GPS. Hope this helps.
Trev |
Posted: Mon Aug 15, 2005 4:41 am Post subject: Thanks |
Thanks for the info Oldboy :D . Is there anyway of editing my postings on this forum? I always seem to remember something else i wanted to say after ive posted, and being i memeber of other forums i know its not very good etiquet to double post. Sorry for double posting again but i would use the edit if only i could find it.
Trev |
dice Occasional Visitor
Posted: Tue Aug 16, 2005 5:52 pm Post subject: Re: Thanks |
Trev7186 wrote: | Thanks for the info Oldboy :D . Is there anyway of editing my postings on this forum? I always seem to remember something else i wanted to say after ive posted, and being i memeber of other forums i know its not very good etiquet to double post. Sorry for double posting again but i would use the edit if only i could find it.
Trev |
You can post new topics in this forum
You can reply to topics in this forum
You can vote in polls in this forum
Thats at the bottom of all threads |
Posted: Tue Aug 16, 2005 6:19 pm Post subject: Sorry |
Ooooops sorry Oldboy it was a long day and at 3.40 am my old grey matter was turning to mush . Finally thought I'd got this TT5-CP5 thing sorted but today my PDA bombed out locking up completely when i tried to access TT5 it wouldnt even except a reinstall ive had to uninstall and start again, it was working great yesterday and all ive done since is installed an application for watching videos not supported by Media player, I cant see that would have any affect but ya never know. well I'll try again and keep you posted with the results. I've got to say i really enjoy this forum its nice to see a friendly place unlike some of the others I've visited. Well done to all those involved in its running, I'll certainly ber making this a place i visit often :D .
Trev |
Posted: Thu Aug 18, 2005 8:17 pm Post subject: Aaaaaaaaaaaaargh |
Here we go again :x TT5 crashed for the second time today all i did before going out was make sure i had the sound files in place for CP so installed over the ones i already had on there. Went to use TT5 every thing ok turned CP5 on then completely locked up the Ipaq, soft reset went through the process again same result tried two more times same result then i gave up. My Partner has the same system as me and has had no problem at all but she never installs new progs or fidles with her Ipaq, so the conclusion ive got from this is that if you install anything after the initial install of TT5 and CP5 it some how affects CP5 or TT5 or the operating system? Next step for me is to reinstall TT5 and CP5 and not update or install anything and see what result i get then, to prove the point. I'll let you all know what happens.
Trev _________________ HP Ipaq 2210
Sysonchip CF
TT GO 520
Nokia 5800xm |
Johnyb Occasional Visitor
Posted: Fri Aug 19, 2005 12:01 am Post subject: |
I took 'Pocketgps' advice, hard reset my qtek9090, reinstalled each application one by one, finishing with 5.0, then 5.1 upgrade, then checkpoint5.0.2
This time no lockup, still flickers, but this is expected.
Does anybody know how to inprove the volume of the warning's audios provided with the speed camera POI's, since it's much lower than the inbuilt TTN5 voices?
Thanks |
