Pocket GPS World :: View topic - Navio 2.1 Released
Navio 2.1 Released
PostPosted: Sun Sep 14, 2003 8:04 am    Post subject: Navio 2.1 Released Reply with quote
I've just received an email from Christian at Tinystocks.com to say they have just released a new version of Navio. Navio is now at v2.1.
Navio gives you access to all the information from your GPS device on your Pocket PC 2002 device or Windows computer (95/98/NT4/Me/2000/XP). With Navio you can:-
  • Check your current position, heading, speed and altitude
  • See how many satellites are being used for your current fix and strength of the signals in 3D
  • See your current location, trace your route and calculate the distance between any two points on any digitized map. This feature is great for travelling, hiking, geocaching, golfing, sailing and much more.
  • Keep track of an unlimited number of waypoints with distance and direction information to each point. Easily export these lists to spreadsheet programs for further analysis. Plot course from waypoint to waypoint on the map. Great for geocaching and hiking !
  • Save all your GPS movement data and replay it later or see the entire route on the map. Easily check the distance travelled, average speed and time taken
  • Works with any serial or Bluetooth GPS device that supports the standard NMEA 0183 message format.
For more information on Navio, check out the tinystocks.com website.
wjrs5
This program is easily the best of its type. It used to be called GSPoT and I recommend all to try it.
22.034 (27 Mar 24)
