Pocket GPS World :: View topic - Illegal or not?
Illegal or not?
Jim-Bob
PostPosted: Mon Jun 13, 2005 11:10 am    Post subject: Illegal or not? Reply with quote
I have a tomtomgo and very pleased with it and the speed camera database. I am thinking of buying a speed camera warning/detection system as a present for someone as he has wanted one for a long time. I heard that laser and radar detectors were becoming illegal so decided against it however I read in the paper this morning an article which suggested it was now only devices which jam the speed cameras which would be illegal. Does anyone know what the law is or is going to be?
Thinking of buying the Origin b2 or the Road Angel I believe each of these have laser detector but a radar detector can only be attached to the Origin. Reading through other posts the laser detector usually only goes off if it is too late (when you are being zapped). Do either of these devices have a GPS based mobile speed trap warning system similar to the Pocketgps database?
Any help appreciated.
LostAtSea
PostPosted: Thu Jun 16, 2005 10:02 pm    Post subject: Reply with quote
Both the Origin and the Road Angel warn only of fixed cameras and D2 sites. They don't warn of the places the police park with a laser gun, unless you store the waypoints yourself.
Jim-Bob
PostPosted: Thu Jun 16, 2005 10:19 pm    Post subject: Reply with quote
Thanx for the reply. Smile
In that case think I will stick to pocketgps database.
worthingsaxovtr
PostPosted: Fri Jun 24, 2005 9:51 am    Post subject: Reply with quote
I disagree the new road angel does detect lasers,
Jim-Bob
PostPosted: Fri Jun 24, 2005 1:19 pm    Post subject: Reply with quote
They do have the laser detector however isnt this just an advanced warning of a letter linding on the doorstep. When this goes off the police have already taken your speed and hence set the detector off?
The lasers dont scatter as much as the radar do they? So you dont get the warnings from them pointing it at other cars.
worthingsaxovtr
PostPosted: Fri Jun 24, 2005 1:22 pm    Post subject: Reply with quote
thats why you can get a number plate detector
as that is the area they focus on
or you could both like I do new road angel and speed camera database on my tomtom
Jim-Bob
PostPosted: Fri Jun 24, 2005 1:28 pm    Post subject: Reply with quote
But surley once it goes off it is too late wherever the sensor is.
I have a tomtom and am very pleased with the pocketgps database. The speedcam warning msystem was a present for someone. Dont think I am going to get in any more tho because I find the mobile database most usefull and think the person who it is for would too.
Thanx for response tho. :D
worthingsaxovtr
PostPosted: Fri Jun 24, 2005 1:56 pm    Post subject: Reply with quote
just a little bit more info for you :D
FAQ of Laser Detectors.
So the question is..... will a laser detector help prevent you from getting a speeding ticket from a Mobile Safety Camera Van.
There are quite a few circumstances that can occur out there. Lets look at a few of the more common ways Laser is used.
The Safety Camera Van and where you place a laser sensor.
Sitting almost anywhere they want on the highway these safety camera vans use much the same type of equipment, Laser Gun, Video Camera, Video Recorder and Printer. The effective range of the safety camera vans is the effective range of the laser gun, some can work a mile away. The effective range of the camera is often much less. 100-500m for number plate recognition.
Most camera vans work quite close to the vehicle in question and this gives a bit of a problem to high mounted laser detectors. Camera van operators also read sites like this to get the edge on drivers. Several police forces are now aware that if they keep the laser sight, (Cross hairs or sight dot), low down on the front of the car, number plate or below, a windscreen mounted laser detector will not see the laser light and will therefore not trigger an alert.
You may recall that in the laser jammer section of this site I tell you to mount the laser jammer low down near the number plate. The same is to be said for laser detectors, place them in a position that the police target, the number plate area.
In an ideal world you would have a laser sensor in the front and back window of the vehicle and a laser sensor by the front and rear number plate. This would give the best coverage.
Several companies do laser sensors that are built into their main units, this is fine for the window coverage but not so good for number plate. Some also do separate laser sensors that are weather proof and can be fitted by the number plate. Check with your chosen company to see what they offer.
So the best place for a laser sensor is both the window and the number plate and they should cover both ends of the vehicle.
The Safety Camera Van and what warning you can expect.
The are lots of scenarios I will cover just a few of the more common ones.
Example 1, Driving from a 60mph to a 40mph. Sometimes the police will target you in the 60mph and follow you in to the 40mph, hoping you don't slow down quick enough. In this case you should get a warning that gives you enough time to slow. You should get away with it and long as you were not over the 60mph.
Effective Laser sensor position - By number plate
Example 2, Safety camera van round bend or over the other side of a brow and you are the first car. You could get a warning but in this case the most likely outcome is that you will be caught before you can react in time.
Effective Laser sensor position - Not much would help.
Example 3, Safety camera van round bend or over the other side of a brow and you are the second car. You could get a warning and might have time to react as they target the car in front.
Effective Laser sensor position - Windscreen
Get the idea, if used in the right way a laser detector can help.
The Laser Beam
Laser guns have a tight beam, so if they target you close and low you window mounted laser sensor may be of no use. Below is an image showing the kind of pattern a leaser beam will have.
To have the most warning you need both a windscreen mounted sensor and a Bumper mounted sensor
Copyright ©
It is very common to drive towards a camera van and get no warning at all and this could be because.
1, You are not speeding
2, They have targeted you low down and your sensor has not seen the laser beam
3, He is targeting another car
4, He is doing something else.
5, He is not targeting your lane
22.043 (17 Apr 24)
