Pocket GPS World :: View topic - 2nd 2500 Mount- Should I Give UP?
Nobber
PostPosted: Mon Aug 23, 2004 10:49 pm    Post subject: 2nd 2500 Mount- Should I Give UP? Reply with quote
Just received a replacement mount for one I had for only a week! intermittent charging, same problem, what is it with these mounts?
should I try again or is there an alternative?
seidioseidio
PostPosted: Sat Aug 28, 2004 4:31 am    Post subject: Reply with quote
HI,
Has your problem been solved yet ? If not, please send me an email
dsc@seidio.com
David Chang
Product Marketing Manager
Seidio
Cs939
PostPosted: Sun Aug 29, 2004 9:51 am    Post subject: Reply with quote
Hi had to register here just to reply to this
Received my car mount from Seidio last week and also had the same problem (intermittant charging), after removing the base cover have noticed that that 2 wires which supply power to the pda have been spliced so that the power is also re-routed to the power Led.
Where the wires have been spliced there is no insulation and these are grounding themselves on the built in speaker 8O
This is extremely poor quality wiring that no decent manufacturer should even contemplate.
You may want to check yours for a similiar problem
Regards
Cs939
Nobber
PostPosted: Mon Aug 30, 2004 10:45 pm    Post subject: Reply with quote
I'll check this out
Erick
PostPosted: Mon Sep 20, 2004 3:11 am    Post subject: Reply with quote
Although I like the fact that the Seidio g2500 functions as advertised, I wish that quality was also one of their foremost marketing features.
I'm not quite happy still w/ the replacement PowerCord- i wish that they would replace it w/ a far more better quality cig lighter power cord (and rid of that 'coil' wires!!, and maybe add a on /off switch).
Speaker is sufficient, but could be better.
Mounting peripherals- yes the suction cup is getting lose (the lever that 'locks' into place is loosening as if stretching from the base of the suction cup itself- i know that soon it will give up!) So I'm looking for alternative mounts where i dont have to use the arm (dont like the vent mount all too much- limits the use of the vents). Are there any 'universal' mount that i can purchase that would fit the Seidio bases?
W/ all the cons, there are good pros w/ the unit.
My 'charging' hasn't failed.
I'm able to charge the BT GPS from the unit itself.
It has a 'clean' appearance, although i wish the dark grey was avail when i purchased this- kinda clashes w/ the car.
Allows me to watch movies also in the car being that it is powered and can be angled different ways (no i dont watch while driving, only at my lunch hour.)
here's a pic of my set up:
22.034 (27 Mar 24)
