Pocket GPS World :: View topic - Memory Map 2004 4.2.4 not working with ipaq 2210
DarrenChristie
PostPosted: Sun Aug 15, 2004 5:50 pm    Post subject: Memory Map 2004 4.2.4 not working with ipaq 2210 Reply with quote
I have an ipaq 2210 with a 2GB CF Micro drive, and 256MB SD card.
So plenty of space for storing maps on with Memory Map.
However when I install the PDA software on my PDA, and then try and transfer the OS maps to my ipaq, it keeps saying the software isn't the latest version, and asking me to install. I say yes and it installs, reporting no errors. It then presents the list of locations to copy the maps to, and it never finds my SD card or CF microdrive, all it lists is main memory.
I thought this maybe due to me using Active Sync 3.7.1, however it is just the same after removing 3.7.1 and installing 3.7.
Does anyone have any ideas as to why this happening? And more importantly how do I get round it?
Or can I just copy the maps across manually and use them?
TC
PostPosted: Mon Aug 16, 2004 12:32 pm    Post subject: Reply with quote
Just a guess, but may be mm doesn't recognise large file systems.
Yes copy the files manually to your appropriate card and everything should be fine. If you have a card reader in you PC put the card in the reader and copy the maps directly. This is much faster than using Active Sync.
Ipaq 2210
Fortuna Clip-on [Xtrac V2]
Tom Tom Navigator 3
Memory Map
22.034 (27 Mar 24)
